- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Well, you got some progress.
I guess I could use the rebar for the oil cap and mower on the intake til I get angle grinder to clean the angle iron.
I dont think I will EVER understand you DAVE, Why would you use the Rebar KNOWING that is 1 of the variables that was causing it NOT to work Previously?
You have to test with KNOWN GOOD WORKING CONTACTS to be able to verify the charger still works.
Yea, I understand what you mean but I was going to use the rebar on the oil cap not the intake. I figured since the oil cap was small that rebar would work also. I have to see tomorrow when I try it with the old charger.
DUDE the size of the Part is NOT why it wasnt working with the intake its because the Rebar is NOT conducting electricity, Using it and posting about it will be worthless
Looks like there's a lot of funk around the mower blade already. Probably ought to clean it off soon.
