Davbell22602 first Electolysis
So can I just paint over the WD40 with engine primer?
No, when you're ready to paint, hose it off with carb cleaner.
If you are going to paint immediatly, then you can blow dry and paint it ASAP. The rust process actually starts instantly all over again, as soon as it hits air out of the water, so it must be treated fairly quick. But I do the WD-40, let all that dry, then probably paint it the next day. But, paint will NOT stick to WD-40.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Turned/rotated intake so the filler tube is near the top instead of at the bottom of the drum.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Thanks using wd40. Do you know that PB Blaster has water in it also. Liquid Wrench is a spraying lube not WD40 or PB Blaster.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Did I miss any spots with the WD40? LOL
Uhh that's a bit overkill. All you needed was a mist of WD40 on the whole thing, not a flood.
jkrenzel
