- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
So I found some. I have LOADS of clamshells of various thicknesses etc but these were a set for sure. THe brackets came off a 1977 350 so should work on mine perfectly. Even though i have the bolts.. I was wondering if you can recommend a good overhaul kit. the one original bolt for the through(long) was almost dust so i cant get a size off it.
also, it appears someone captured the nut with a welder on the one side.. is that a factory thing or did someone decided clearance was going to be HIS bitch that day?
oh and do i just search poly sbc mount inserts? gotta put new rivets in? what kind?
edit:
@bucket perhaps since i have an NP208 and crossmember/mount out of a 1985 or so square, i should find the motor mount and brackets used for a 350 those years? maybe its putting an angle on the whole shebang? Too low or something?
edit:
