Motor mount question
So I found some. I have LOADS of clamshells of various thicknesses etc but these were a set for sure. THe brackets came off a 1977 350 so should work on mine perfectly. Even though i have the bolts.. I was wondering if you can recommend a good overhaul kit. the one original bolt for the through(long) was almost dust so i cant get a size off it.
also, it appears someone captured the nut with a welder on the one side.. is that a factory thing or did someone decided clearance was going to be HIS bitch that day?
oh and do i just search poly sbc mount inserts? gotta put new rivets in? what kind?
edit:
@bucket perhaps since i have an NP208 and crossmember/mount out of a 1985 or so square, i should find the motor mount and brackets used for a 350 those years? maybe its putting an angle on the whole shebang? Too low or something?
Your brackets should be fine, just worn rubber mounts. Those brackets pictured may or may not work, depending on what they are out of. I know some cars had that captured nut arrangement. '85 engine mounts are the same as '80. Just your t-case mount is specific to a later year.
Well the bracket SHOULD be a 1977 k25 with 350, sm465, and np205 just like my 1980 but 1977. thats at least based on the trunk full of parts from one lol
based on the welds i think it was welded there by either PO or my gpa. perhaps the clearance around driver side with z bar and etc motivated it lol.
I dont see any harm in going to a quality poly instead of rubber, then i dont have ot touch them again. any leads on hardware that is good or if they need rivets
I just use the common Energy Suspension brand. They come with zip ties to hold it together before they are bolted down. I just prefer to use rivets.
oh its jsut for the convenience, ill prob use some peen rivets i have so many and never used one in my life yet lol
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I am using a 1980 K30 frame that had a 350 to put my 1981 C20 body on as well as installing the 454 that was in the C20. The mounting holes were close, but I had to weld up the old holes and drill new ones. You can see in the pic the pilot holes for new locations versus the factory elogated holes.
k30 has different rail stuff tho doesnt it
im going from 3/4 to 3/4 ton same engine and trans even lol
HOTFOOT
northwest ct
michael
gmc k3500 srw
had a 77 k20 suburban with a 400 sb removed it and installed a 454 and the hood still closed, fan shroud was a little close to alt. but did not change anything
staverironbrand
