Intake Manifold Install
gmbellew
Kansas city
glen
suburban 1500
That is Exactly where mine is, I painted the intake and used thread sealer would that be an issue?
Rusty Nail what is your suggesion to locate the Grounds, Battery And small wire ground??
It was all fine before i Installed new Gaskets
ground work best on bare metal. although I am not sure if that is the result of your code 42 (if you are still getting code 42). did you disconnect the neg terminal to clear codes and try again? if code 42 comes back, follow the diagnostics in the drivability manual.
Mango
JacksonWyoming
Gil
Yes Code came Back
Where would I find That Manual
Rusty Nail
Rusty
350sbc
The battery oughta be grounded on the core support??
( I hit him with the double question marks - just for you Bellew?? )
I'm doin it all over the inner webz now??
Mango
JacksonWyoming
Gil
Rusty Nail EST wire clear thx
Large ground strap to frame
Mango
JacksonWyoming
Gil
Would a old ignition pick up cause the random stalling, it was fine before i pulled out the Distributor
Rusty Nail
Rusty
350sbc
Maybe. The pick-up coils fail given enough years and* mileage. They're magnetic??
Mango
JacksonWyoming
Gil
Why would they fail now after a intake manifold gasket replacement
gmbellew
Kansas city
glen
suburban 1500
what is this vacuum arrangement? looks like something that should be hooked up to the TBI is Teed into the PCV valve line?
Mango
JacksonWyoming
Gil
Goes to the canister that was there the whole time
thanks It does connect to the TBI
Could a bad temp sensor cause stalling
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Nice build! Looks like you have replaced wiring harness and everything.
Mango
JacksonWyoming
Gil
Original Harness Wire Mold, wish it would run
Mango
JacksonWyoming
Gil
Trying to find the issues
gmbellew
Kansas city
glen
suburban 1500
I'd still look at the vac hoses. the cannister, PCV, EGR solenoid, and MAP sensor should all come off different TBI ports. some are manifold vac and some are ported vac and it probably matters that they are all on the right ports. that might not be the issue, but while you are messing around may as well get it correct to match the sticker under the hood
TDW1
