WFarm
- Jan 11, 2023
- Central Virginia
- Paul
- K5 Blazer
When I installed my new radiator and electric fans, I installed the fan temp switch (190 F turn on) in the left side head. The coolant temperature sensor is installed in the intake manifold and was not touched. Normal coolant temps run right around 190 F. and can be monitored via the Dakota Digital dash.
Since I also installed a dash mounted indicator light that lights up when the fans are energized I can see at what coolant temperature this occurs. Seems the fans are coming on when the temperature gauge is reading only 153 F. I read that the coolant temps in the head will run maybe 10-15 degrees higher than the manifold temps, but this 37 deg delta seems high.
Is this much of a temperature delta between the cylinder head and intake manifold locations unusual? Wondering if I have a bad temperature switch or if I should relocate it.
