How Will My Square Body Look With XX Lift and XX Tires?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
This thread is great, really helps visualize what a lift and tires will do to a truck.
I'm thinking I would like about 3-4 inches of suspension lift, and run 33's on my 78. What is the point where you have to start doing major driveline and steering changes? At 4" can you just do springs, shocks and a dropped steering arm, or are there other things you should change? My truck will spend most of it's time on the street, but I will do some off roading.
I might be wrong, but I think 4" is right about where you should start addressing the steering.
my truck has 33s, don't think its lifted though...doesn't rub and clears well everywhere.
tdub209
Tracy, CA
TJ
k20
Stock Suspension with 265/75r16 Hercules M/T and 16x8 Helo Wheels
Stock suspension still with a 305/70r16 Pro Comp A/T and 16x10 Weld Super Singles
(rubbed passenger inner fender a little)
And the lift starts..
6” Front spring
Ruff stuff Specialties 2” longer front shackle
Add a leaf for the rear and a 4” block
16.5x12 Weld Commandos on 33x12.50r16.5 BFG M/T
Lifted on 18x10 MB wheels and 35x14.50r18 Super Swamper Irocs
16.5x10 Weld Scorpios on 37x12.50r16.5 Military MTs
16.5x14 Bart wheels on 35x14.50r16.5 TSL’s
16.5x14 Bart wheels on 39.5x18.00r16.5 Boggers
And currently on stock GM wheels waiting for the 37x12.50r17s and Method wheels to me mounted for it. but motor and dash need to be finished first lol.
6” Front spring
Those first couple pics look like stock spring packs, but they look to have been re-arched. Or about a 3 inch lift.
tdub209
Tracy, CA
TJ
k20
first tow pictures were completely bone stock. i still have the springs and they are flatter than a pancake
1badk20
1badk20
I understand that. Flat springs makes for about a 2.5-3 inch lift. Your second picture shows the flat arch very well, as well as a stock type spring eye. But the stock springs were negative arch. That's why the evidence points towards stock springs that had been re-arched for a mild lift. You appeared to have more tire clearance than a stock truck would, which is why I got to looking close at the pics to begin with.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'm agreeing with bucket. Something was done to your stock suspension. Here is what mine looked like with stock suspension and 265/75R16 tires:
And here is is later with a 3" lift and the same tires:
78C10BigTen
pennsylvannia
C10 BIG TEN
Heres my 94 with 3" blocks in the rear and turned up torsions in the front, granted its on 33's... i have a picture of normal 265/16s with the same lift somewhere, i cant seem to find it but 3" makes a huge diff over saggy stock leaves.
78C10BigTen
pennsylvannia
C10 BIG TEN
Opps im sorry i forgot to put in the pic b4 i hit post. :Stupid Me:
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
So you'd say when 4" lift is added things have to change? What was the size of those wider wheels they sometimes put on Squares? like @Dieseldave01's. Thanks!
78C10BigTen
pennsylvannia
C10 BIG TEN
His profile pic i believe they are factory. If i remember there like 8" or 9" wide steels, look about 16". Ive seen it in a thread here b4 somewhere.
Iowan
Iowa
Calvin
K1500
350 crate
Yeah, I think honkey knows, but what doesn't he know....:emotions34:
Dieseldave01
oxford Ohio
Dave
I was told by previous owner these where a rare factory option, I believe they are 8.75 wide and 16.5 diameter
Iowan
Iowa
Calvin
K1500
350 crate
I thinks you have onw of the BEST looking trucks on the forum!!!!!!!
I agree, it's a damn fine looking truck!
The factory wide steelies were 16.5x8.25 and 16.5x9.75 although I'm not sure the widest ones were ever available on squares, maybe just the '72 and older trucks.
Jimc21NC
