Will this work with 35s?
Fastduramax
Uranus
K10 Silverado
Awsome rig....
Redfish
Prairieville, LA
Andrew
V1500
Awsome rig....
Thanks, but it's a little rough if you saw it in person. I am also running a Skyjacker front lift. The truck had blocks in the rear. In hindsight I should have paid the extra money and got the rear Skyjacker springs. That is still on the table.
I want more rake than I have, to get it like this I removed the bottom "helper" from the front. I was trying to keep it from getting too high and wanted a true 1980s style and look. I am also running 33x12.50-15s. So far they don't rub.
The Skyjacker Softride 2.5" front stack:
The removal of the helper:
Fastduramax
Uranus
K10 Silverado
Yes sir Skyjacker has excellent ride quality especially when you utilize their rear springs... One hugely popular name I'd never use again is Rancho, horrible ride quality unless they have vastly changed in the last 10 years... My truck by the way does not have quite as much rake as it appears in my avatar...
Camar068
Kentucky
10 yrs Air Force
am I the only one to notice all the orange peel? Sorry but I trust my Dad and he says if you know what your doing, you won't have orange peel. I don't care to say that because I've never seen a vehicle he painted since the early 80's that had orange peel. I'm guessing he had 1 or 2 that I didn't see and he scuffed and painted again.
Looks nice from a distance but not $23k distance.
Auburn, Washington
@Camar068 Lol, yeah it looks horrible. I didn’t look hard at the pics before. It’s a fugly backyard job. Zoom in on the front of the hood!
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
My 91 Suburban is running 17x8.5 Method MR701 wheels and Nitto Terra Grappler G2 - LT285-75R tires....34" tall and about 11" wide and I have not had any rubbing after tapping in the back of the front fenders with a hammer very lightly. I don't run it off road but it is a daily driver. The wheels did need to be moved out for them to clear the tie rod ends which I did by swapping out the brakes with Hummer brakes and relocating the rotor to the outside of the hub. I admit it is close but it works so far.
Camar068
Kentucky
10 yrs Air Force
aside from the tires and paint, I like it. I really like the tweeter location and the shifter. Shifter looks high enough to not have to reach down.
AZ squarebody
Scott
K15
Did you have to put longer wheel studs in for those method wheels?
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
Just saw this. Sorry. Yes, longer studs on the front but the back worked fine. I had to put new studs in the front anyway because of the rotor location change.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
The engine would be sweet, but based on other shortcuts, I’d question the execution. Doesn’t look like the trim was pulled for the repaint and front lift blocks on stock springs… interesting choice.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Huh?
Rusty Nail
Rusty
350sbc
Who bothers to install a posi in the front when you've got locking hubs??
Good way to break isht.
Im calling bullisht.
/BULLISHT!
JoeyPepperoni
