How Will My Square Body Look With XX Lift and XX Tires?
Will Chastain
GA
Will
I’m wondering if a 6 inch rough country lift will clear a 37-13.50 on a 15x10 wheel?
8 inch would be optimal for a 37 but wheel offset will matter too. Military wheels or HMMV wheels have the wrong offest. You could have them worked over and they make it otherwise no U turns without trimming. it's not cheap to have them recenteded so I've been told. Also depends on how aggresive you want to be. You may get it to work for a street princess but get out in sticks and getting a little rough they'll hit occasionally.
Rajin Cajun
Joey
How will my 86 c10 long bed look stock height,15x10 wheels with 4 inch back space,and 29x11.5r15 super swampers
77 K20
Montana
K20 5" lift
HT383 fuel injected
ORD front custom springs, 4" lift. Rear lift was a 2.5" shackle flip and new OEM springs. Rear was lifted 5.5"
New BFG KM3 tires, 315/75R16 on some 16x8 steel wheels. (new tires vs old KM2s in 285/75R16)
This pic fits here better than anywhere else so even though it's mis categorized....
Eh, I dunno. That's more like a truck pulling up on 44's.
I'd have to agree, gonna need a lift kit though nontheless or they're gonna rub for sure.
Camar068
Kentucky
10 yrs Air Force
I like it, but do they make nobbies/tread like that for the rear like they do on the new semi's where it's one tire? If they do, I'll be looking at dually crew cabs more. they are often cheaper than non-dually.
You mean a super single? You gotta go big for that, with a 22.5 rim. They are heavy truck/implement tires, nothing that I know of specifically for use on a pickup.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
2" rough country lift, 33x12.5x15 tires
Pretty sure the tires are underinflated quite a bit too. Haven't been driving her much lately.
77 K20
Montana
K20 5" lift
HT383 fuel injected
for a tire that wide on a 8" rim it is very easy to over inflate them and then the tire just rides on the center of the tread.
You can take some chalk and draw a line across the tread and then drive straight for 50'
or so on pavement then get out and look to see how the chalk is wearing off. Then adjust the tire pressure accordingly.
The shop filled my tires to 70 psi after mounting them. It would rub off in the center and not at all at the edges. Think I'm down to 35 psi now.
seanhatesregister
