1987 Suburban R10 emissions problem due to modified intake
thatgermanguy
Colorado
Jochen
I got this sweet Suburban last year and needed to register it in Colorado. It failed emissions on HC and CO. When I bought it I noticed some tubes that seemed like something had been removed and the owner in Idaho (where they don't have the same emissions test requirements) said it was an air filter "some crap for California emissions you don't need" that he had removed. So... what did he remove? Could it be a reason for the poor emissions test results? Are there any tips people can give me on how to get the car to burn more cleanly? Plugs? Filters? Tune up? Additives? She starts and runs well but it smells like she doesn't burn all the petrol... Love this car and really want it to pass. Thanks! Here are some pictures that might help...
I saw this schematic that seems relevant but little explanation. It seems that the removed parts were the Air Cleaner unit... here is a link. Does that seem right in explaining the poor emissions performance?
https://www.gmpartsnow.com/oem-parts/gm-air-cleaner-25042891?c=Zz1lbmdpbmUmcz1haXItaW50YWtlJmw9MSZuPUFzc2VtYmxpZXMgUGFnZSZhPWNoZXZyb2xldCZvPXN1YnVyYmFuLXIxMCZ5PTE5ODcmdD1zaWx2ZXJhZG8mZT01LTBsLXY4LWdhcw==
dd1990
Ventura CA
Suburban 1500
Sounds like your missing the stock air filter housing and preheat tube. This would not affect emissions out the pipe but it would not pass the visual in California, don't know about CO. In terms of emissions, a tune up will help, BUT do you still have stock intake manifold, tbi, with egr and all vacuum hoses attached? Do you still have a catalytic converter that would be the biggest problem if missing.
Without pics we are guessing about a lot here. Please post pics of the engine so we can see the mods and try to help you.
fast 99
Spokane, Washington
Is an under hood visual part of the emissions inspection? If all the vehicle needs is being lower than the limits an air pump and cat do wonders on emissions. Here they only did under hood if the vehicle needed a waiver. If everything installed by OEM is required some of it may be difficult to locate.
thatgermanguy
Colorado
Jochen
Visual is not a part of it here. My HC and CO values are too high. I've attached a pic above!
thatgermanguy
Colorado
Jochen
Sorry I thought it had loaded. Here you go. You can see the cut hoses.
fast 99
Spokane, Washington
Will help to know how clean the exhaust needs to be. What is the emissions limit and vehicles reading.
Turbo4whl
Downingtown, PA
Wayne
Yes, the A.I.R. pump plumbing is missing. HC would would be higher. With higher HC, the CO would also go up. This may not be all that is wrong.
jlyon1006
