Anyone rocking S10's?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
My k5 is lol the s10 isn't, besides, would you really believed I killed a Rockwell with a 4.3? [emoji1787]
Sent from my SM-G965U using Tapatalk
I know your Blazer is and if you blew the gov bomb I knew it wasn’t in a Rockwell lol
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Im gonna be perfectly honest with you, once the build it done, I'm gonna run it on some tests, play around, take it easy, once it passes the "crawling/walking" stages, I'm gonna push those axles as hard as I can and try to break them, full on loaded launches in a attempt to try to grenade them lol after all, that's what they were bought for! "bombproof".... We'll see what the 502 has to say about it
Vbb199
Salisbury NC
Vince
Another center is about 250$ for me, if she dies, I'll throw another in
What Honky meant was, an 8.8 swap would be a walk in the park compared to your K5 build. It's nearly a 100% bolt-in deal.
They use a flange type pinion yoke. The donor Explorer's shaft can donate it's rear yokes and you can probably adapt them to your stock shaft.
Then the wheel bolt pattern would need redrilled to the Chevy pattern.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
There is a conversion joint to put the ford yoke on a Chevy shaft. Most just get another short shaft and cut the housing so the chunk is centered otherwise it’s offset
Vbb199
Salisbury NC
Vince
I'm interested, anything is possible with the tools I have available. What's the bolt pattern for the furd?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
5x4.5 or 114.3 or some shot like that
Vbb199
Salisbury NC
Vince
Ah, so I'd have to crossdrill the wheels, or crossdrill axle shaft and hub/rotor
Vbb199
Salisbury NC
Vince
Only thing I'm trying to visualize here. Is the furd 8.8 center offset?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Drill the rotor and axle
But that's just for 2wd use though I thought. The 4x4 housing is wider, so you kinda need to keep the width?
Imho, if an offset pumpkin works in an Explorer, it will be fine in an S10.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Your correct.on the width thing I had 2wd in my head even though he said 4x4
Vbb199
Salisbury NC
Vince
Well I mean... Guys out there are OK with running 45° on their front and rear driveshafts with big lifts and no case lowering /drop box
Couldn't see why a offset pinion would hurt [emoji1787][emoji1787][emoji1787][emoji1787]
2manysquares2care
