77 K10 LS Swap
Camar068
10 yrs Air Force
nice work
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Finally got around to cleaning and inspecting the front hubs. The bearings didn't look bad and cleaned up well. However, both outer bearing races were loose in the hub. Not cool!! New hubs are not cheap. This drove me to do a little research, Loctite makes a couple products for just this scenario. Just ordered a small bottle of Loctite 680. Worth a try for $17.
Camar068
10 yrs Air Force
I suck at this part of the truck, pics or can you elaborate?
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
what paint did you use? prepwork besides wire wheel and degreaser?
Madhorn
AR-Arkansas
Ken
prep consisted of wire wheel and carb cleaner. In the first pics I had used Crylon satin. Didn’t like that so I went over satin with matte. Will post pictures later of the hubs.
Madhorn
AR-Arkansas
Ken
Outer bearing race in both hubs are loose. Not sloppy but can be removed by hand. Should have the Loctite 680 I ordered tomorrow. Should fix the problem.
Madhorn
AR-Arkansas
Ken
Drivers side going back together.
Madhorn
AR-Arkansas
Ken
Passenger side. Top ball joint needed an offset bushing for zero camber. Both sides check out with digital level.
Madhorn
AR-Arkansas
Ken
Once the hud bearing races are good to go I hope to have it back together this weekend. Already made an appointment at the alignment shop for next Friday morning.
Madhorn
AR-Arkansas
Ken
getting closer
Poppy 87
Bloomingdale GA
R10 Silverado
Looking good. Hopefully the alignment shop has an old timer ( like me) that knows what the hell he's doing while setting your truck. Get a print out of before and after measurements. Good luck
Sent from my XT1254 using Tapatalk
Madhorn
AR-Arkansas
Ken
Just found out the Loctite 680 I ordered Tuesday didn’t ship until yesterday. Was supposed to be here yesterday. Looks like I am in holding pattern until it gets here. Bummer.
idahovette
Weiser Idaho
Perry
K20-K10
Be sure and ask for the print out, if he is an old timer. I ALWAYS forgot to do the before printout. Then I couldn't show what i actually did, DUH!!! But than again I am old and slow(and forgetful)
Madhorn
AR-Arkansas
Ken
Not much today. Drag link, shocks and pinion seal.
Madhorn
AR-Arkansas
Ken
Diff is full of fresh gear oil, tie-rod and steering stabilizer installed. That’s all we can do until the Loctite for the wheel hub outer races arrives.
seanhatesregister
