The swap started today.....
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Ok so I got the engine and tranny installed and I was lining up the driveshaft to make sure I could use the old one. Length looks really close but cant say for sure because the yoke that was on the th350 is too small for the 4l80. Anyone know if I can just get a new yoke or do I need to get the whole driveshaft? I guess the question is "will a 4l80e yoke work with a driveshaft from a th350"?
The LSX Innovations plates move the engine forward like an inch, or 1.5. Then the 80E is 31 1/2 " long, a long TH350 is 30 5/8" . The yoke from a TH400 is longer I believe as well, so.. IN theory, yes you should be able to put your yoke on the driveshaft and rock and roll.
Now, that said, the keyboard warriors will tell you that you'll exceed the speed of the stock shaft, and die. I wouldn't lose any sleep over it, but for me, locally, I can have a high speed balanced all new driveshaft for 300 bucks. SO your call.
gpmorgan
Tupelo Ms.
greg
Summit has all types of yokes and conversion u-joints. I recently went from a 700r4 to a th400 and that's where I found what I needed.
4WDKC
Southern Florida
Kacy
Nah I ain’t gonna fight over them @4WDKC has a nicer truck then me. they would just get beat to **** on mine any way.
Are we talking about the same truck? I need to get a front bumper for it, not sure one would fit withe the bumper torn the way it is.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yeah lol
Biggin0822
Michigan
kevin
Engine and transmission are in. Transmission lines are run to a new transmission cooler. Shift linkage is "mocked up". Just have to put a little bend in the Lokar kit shaft. Fuel just need 2 hose ends to be cut to length and fittings installed to connect to the fuel sending unit.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sweet!!!! Soon time for a video.:waytogo:
Jrgunn5150
Ionia Mi
J.R.
6.slow
Are those the Russell AN to GM adapters?
Biggin0822
Michigan
kevin
yes they are. Got them locally at "Auto Masters" It's like having Summit 30 minutes from home.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Watch them closely, they are known for leaking, the newer two piece ones are alot better.
Biggin0822
Michigan
kevin
Looking for a radiator/fan combo recommendation. I'm not looking to spend 800 to a thousand, so should I be hunting ain a junkyard or are there new options in the 4-500 range that would work well?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Jrgunn5150
Ionia Mi
J.R.
6.slow
Use the Spectre 454 radiator, and literally any Ford E-fan from the boneyard from 93 or so up.
Or, go more expensive, and get Tejas Steelworks pre-made shroud to run dual LS1 car fans.
seanhatesregister
