Lifter tick?
fast 99
Spokane, Washington
I have a stethoscope and frankly I’m having a heard time isolating the noise. It sounds loudest when touching the head between the headers and valve cover, but I could also be wrong. No flat tappets.
If style with a hose on it remove the end piece. Any exhaust leak will be quite noticeable as air passes by the end of the open hose.
Chebbyman
Green Cove Springs FL
1500 Cheyenne
I have a pro built 383 flat tappet hydraulic cam in my 36 Chevy street rod w/roller rockers (dynoed @ 455 HP, 468 FtLbs). Yes, I use a zinc additive. It is a little noisy when cold but quiets down when warm. My 2016 SS Camaro with the LT 1 also has roller rockers and they are slightly noisy. My 02 SS Camaro w/LS 1 was a little noisy(blogs used the term "sewing machine sound". I have not trouble with any of these motors. I have always thought that the roller lifters were a little noisy. (Told by several mechanics and the dealer that this is normal for roller rockers)
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Adjust the valves while you have the covers off. Use the two-roll method.
When I first read this, I was thinking of Tommy Chong on Up in smoke....glad you clarified that. Not that there's anything wrong with that...
1lejohn
texas
john
k-1500, 2500 HD
They are inherently noisy. I have a tick on my 85. It has retrofit rollers and a mild GM cam. The noise has been there since day one of the install. I also have had real noisy lifters from Comp Cams on one of my LS builds. I would check them and move on.
sam s
