Taking off passenger head about 37 bolts so far
Status
Not open for further replies.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Im assuming its an auto. Underneath Remove inspection cover if applicable. And remove the starter and torque converter bolts, should be 3. Helps to have someone hold crank but not impossible to do all yourself. And get in the habit of only turning the engine clockwise. After that remove engine mount bolts and bell housing. Also have a floor or transmission jack supporting transmission.
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
Gasket from no compression side
Rickf
Grafton NH
1974, 1954 & a 1937
In for a dime, in for a dollar. Looks like a blown head gasket. If it was mine, I'd pull the nose and get a Harbor Freight engine hoist for ease of removal.
Hugomartin
Banned
Nc
Hugo
Mystery are there any other bolts here I must undue? I just see this one I’m pointing too a bar with my red black ratchet handle Is this just a stabalizer bracket bar connecting the block to trans? It’s a 9/16 bolt if I undue this bolt will it free the engine from trans?
Hugomartin
Banned
Nc
Hugo
Nevrmind got it out it I have a jack under trans
Hugomartin
Banned
Nc
Hugo
Do I need to undue anything here ?this is driver side underneath. Is the “thing” to the right of the flywheel called the torque converter? Won’t that part stay attached to the Tran wen I get the motor out?
Hugomartin
Banned
Nc
Hugo
On this engine mount should I only remove that bolt I’m pointing too
Hugomartin
Banned
Nc
Hugo
Should I only remove the single bolt in engine mount this is passenger side
squaredeal91
Greg bush
1991 SB
Remove the 3 torque converter bolts before pulling engine.
Hugomartin
Banned
Nc
Hugo
Thanks so the “thing “ between the tran and flywheel is a torque converter ok. Where are the three bolts?
Thanks
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Thanks
Backside of flex plate, towards engine is where the heads of those bolts are.
BUY A BOOK!!! It will be more valuable to you than you know, and save you COUNTLESS hours and an unbelievable amount of frustration. Example post 71, you are asking about that big thing. You see I know how that big thing has to be seated, before I install the engine, you don't, the book will tell you that before you bend up a flex plate, or break a front pump. That is only 1 example.
Hugomartin
Banned
Nc
Hugo
Thank you it’s a 5/8 also how do I keep this fly torque thing from spinning when taking out this bolt
Status
kobedemello
