Pioneer Stereo
So theorange on the wiring harness is for the lighter shouldn't I be able to connect the yellow to that and it work
Not the best way to do it but yes that will work.
GunMan9
Yorktown
Brandon
It will not affect anything correct
Driver4r
Nebraska
Trevor
k10,c20
Ummmm, why would he run a 12v plug off of a radio circut?????
Is that wire pluged into anything on the original plugs?
Thats a universal adaper, its the same setup in my monte and my monte has a remote antenna, so mabey that wire is power for an antenna, which in this case would not be used.
GunMan9
Yorktown
Brandon
I have no idea. This is how it was when I got the truck
GunMan9
Yorktown
Brandon
No not that I know of
STOP!!! That orange wire you asked about.....For Pioneer radios that is for Illumination on the Pioneer radio which only matters on double din radios which yours is a single din. Keep that orange wire capped off as there's no use for it on your radio. Run the red wire to your ACC power and the yellow to your constant 12V power to keep memory.
GunMan9
Yorktown
Brandon
So what exactly do I connect the red wire to on the harness and the yellow wire to so I don't mess this up
ACC power is basically the same as when your ignition switch is flipped back one notch where you can listen to the radio but the truck isn't on. ACC stands for Accessory power. I'll have to crawl under my dash to see what color that is on our trucks. I'm sure Retro or someone like that knows that off top of their head. For your yellow wire needs to go to your constant 12V power in order to keep your memory on the radio.
GunMan9
Yorktown
Brandon
So I can't just simply wire it to another wire on the harness
GunMan9
Yorktown
Brandon
So I need to run the yellow to the fuse box?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Yes. To the left side of the fuse box in the pic that 89S posted.
attachment.php
GunMan9
Yorktown
Brandon
Do I just splice the wire and put it in there or is there and adaptor I have to get?
ryan1986
