my 88 k1500, tons of pics
Swims350
Logan WV
none
sure do have the originals and I'm looking to sell lol. I got the bolts and all.
now for today....
found somethings a bit interesting tearing down the front, well removing the fender.
that doors been hard to shut and makes a loud pop when it catches you have to pull hard, roller pin is bent bad. I knocked it out, going to order a new one for both sides. The ds has been missing as well as the ds door spring since I got the truck.
Also notice anything wrong?
yea removed that bolt and that come with it. It's broke clean off and has been for quite some time, has rust on it, no clean metal.
Now that I kept yall waiting long enough, I got some PAINT ON!!!!!!!!!!!!!!!!!
Swims350
Logan WV
none
ps, aint sure if that's dust of the flake in the up close one.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
PM sent.
That looks like O77 blue, at least in the pics.
I like how the fan shroud turned out, what kind of prep did you do to it prior to paint? Looks like it still has the factory texture.
Swims350
Logan WV
none
I know it turned out very well. I think it turned out better then the inners.
I tried to remove the somewhat texture it has, but it didn't work too great I guess, maybe just orange peel somewhat.
Anyways, prep, stripped the krylon fusion I had on it off with gel paint stripper, sanded it down with 150 or so i think, then used duplicolor adhesion promoter, then some rustoleum filler primer. wetsanded it with 320, then knocked over it a little with 400 wet, just barely though. No real need the 320 made it nice and smooth. I then just used grease and wax remover, then tack rag and sprayed it.
That should be pretty smooth then, the pics must be playing tricks on my eyes. Smooth or textured, I still like it :)
Swims350
Logan WV
none
yea I do too. it may have some texture though, no biggie it's done now so I'll live with it for sure.
Swims350
Logan WV
none
more work done today..
Swims350
Logan WV
none
more work...
couple pics of the flake
davbell22602
Bunker Hill, WV
I Dont
Have
One
Nice work. I'm totally against using body filler. IMO
Swims350
Logan WV
none
there's no way to be againist it it's a must have.
You want a panel straight and perfect have to use it. Only other way is tons wasted in high build primers and such.
Filler is nothing to be afraid of or againist, you just don't build it up thick. a general rule of thumb is it has to be less then 1/4 thick, 1/8 or so is good. Less is better.
davbell22602
Bunker Hill, WV
I Dont
Have
One
A fellow student bought a 67 pontiac catalina convertible. I about puked my guts out when I saw where someone used it fill in rear lower corner panels from bottom to half up with nothing but body filler. I thought he paid too much for it over. Its had running SB 400 but need work and needed a new convertible too. Most I pay for it is $300-400. He paid $600.
Swims350
Logan WV
none
awesome lol.
can't wait to do the outside and have it done, then cut and buff it to perfection i hope LOL.
wife picked it out, she looked at the color book and just stopped, I was thinking more of a red or lighter blue.
He stole it for $600 even if it needed fully restored and was found tore up in a pasture.
scamp811
