- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
why go from a fender bolt lol, so far away. Id go to the floor before the fender.When we got the truck, the girl pointed out that there was a random wire that went from under the hood, through the door jamb, then up into the dash somewhere. She didn't know what it did, so she never messed with it. Well today I figured out what it did, and that another previous owner was an idiot. They obviously knew that the cluster had a bad ground, because that janky wire went from a front fender bolt, to the gauge cluster. The only problem was, they had the wire attached to a cluster mounting screw... which is a plastic cluster, mounted to a plastic dash. Idiots, lol.
I just ran a ground from the brace near the battery on my gmt800 to run to each sidemarker, because i have ghost voltage on the ground side (the side that the turn signals are supposed to power only for "switchback") , and I thought I was being cringe running from the driver fender to the passenger headlight lol.
