Maybe that negatvie clamp isn;t getting a good bite on clean metal too? Maybe stick a bolt in the manifold somewhere to clamp it on? Dave, show us some pics of what's going on man, let's see that rebar.Good Question Sky. If its at Zero or real low, its not working. As your rebar gets dirty, your amps will drop too.
I have heard that distilled water does work better, but tap water will work fine too.
I have a feeling his charger on 50 amp, is not working. Its detecting a dead ground short and not coming on. Need to do 10amp Dave. Also make sure your connections are good.
I put 17 gallons of water to 17 tablespoon of washing soda. Didnt do anything on 10 amp either. I think this battery charger is too cheap of a charger cause I would get funny readings and then go back after the charger cooled then it would read fine like something that window with needle is getting stuck or hung up at times.
Will empty water half the water tomorrow and start on 10 amps to what happens.
Sounds like your batter charger is like a few women I know. They aren't puttin out and sending false signals !!!
I can't beleive you didn't dump half the water out today. How hard could that be??? Also get a bolt and bolt it into the carb stud hole with a jamb nut so you can make sure its good and snug without driving the threads thru the manifold and breaking it.
I put all that water in there so it would clean the filler tube but I guess I could stand it up on its end for that so i could use less water. Might have to buy to one of those schumacher ones at walmart.
I dont know if bolt will thread into a carb stud hole cause how rusty 2 of 4 holes are. Could I just thread a nut on 2 of the other studs that are already in the intake?
