fried_daddy
- Apr 7, 2019
- Elkmont, AL
- Matt
- R1500
- 5.3 LS
Nice work!You are reminding me of all the fun I had with my LS swap in my k5.
I didn't go to the extent of installing a new cam but replaced all gaskets, seals, sensors...
I went with shorty SS headers since I have limited space. Was able to run true duals.
I also used the donor overflow tank and radiator with e-fans.
For the motor mounts, I have the stock mounts on the sub frame (k-member) with LS swap brackets. Can't recall the name but they set the engine back 1 inch. This allows the use of the stock driveshaft.
For the AC compressor, not much you can do without a new bracket. I plan to install a high mount one with a sanden compressor. It will basically sits in front of the right head.
For the fuel pump I went with a DeatschWerks. Had many good review and works well for me.
I also built my own lines with An6 and used the vette style pump/regulator.
My harness was intact and removed from a running escalade. I reworked myself and made my own power distribution block with fuses and relays.
For the trans, I like having overdrive. I would go with the new one. There are plenty of people that would buy you TH400 if you wanted to sell.
You can see some of my build in signature.
Yeah. I think I will have plenty of room for long tubes with my truck being a 2WD. I got a radiator and overflow tank from a LS donor vehicle. I decided to go with the clutch fan instead of electric fan. I like the roar, and I didn't wanna go through the expense and additional electrical required to control electric fans. I plan on using the stock driveshaft for now so hopefully the slide on mines will let me sit it in the right place.
I began on making up the AN fuel lines this morning before work. I'll prob continue those over this weekend. Going to check out your build thread!! I'm planning on keeping the TH400 for now. I just rebuilt it a few months ago with new frictions, steels, bushings, seals, the full rebuild kit and the 4L80E 34 element upgrade and a shift kit. This will be a backup in case I blow up the 4L60E.
Going to check out your build now!!
