1994 S10 1Ton SAS
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Saturday I got the front tore down, it took the sacrifice of cheap 3 rachets, (impact wouldnt budge some of the bolts)
I rounded off a few of the spindle nuts that bolt the spindle to the knuckle, and lower kingpin cap bolts were pretty stuck. That essentially consumed most of my day Saturday
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
She is coming along nicely. Damn good job man. I am as excited as you for the end product.
Vbb199
Salisbury NC
Vince
Sunday I made a nice pile of s10 IFS parts.
Started fitting up the dana 60 with rachet straps.
(all the u bolts and parts I need are ALL on order)
Vbb199
Salisbury NC
Vince
Here the real kicker. Now this is only an "eyeball" estimate for now, but I picked the front end up with my hillbilly gantry until the axle tubes were level with the center of the 39.5's......
Boy was something off in my measurements ... She's gonna tower those 39.5's
Vbb199
Salisbury NC
Vince
Rear axle, there wasn't much to be done.
Brakes ,r otors, and calipers all looked good. All I did was weld down new pads for the 38.5 Centerpin distance of the s10. U bolts are on order. Once the front is all welded into place securely enough, Ill jack up the rear and slide this into place
Vbb199
Salisbury NC
Vince
And lastly a pic for entertainment.
1 ton stub next to a 1/2 ton stub.
That's all for today!
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Thats something we should all take into account running big tires. Lol, David VS Goliath.
dvdswan
Port Orchard, WA
Dave
Looking good. Just my opinion, but it would be better to have the shackles on the rear of the spring.
Vbb199
Salisbury NC
Vince
Wish I could, but due to the shape of the s10 frame, doing so would drastically kick my front pinion downward.
You can see it here when I was visualizing the whole thing... Makes more sense to run front shackles.
At this place it rests now, the leaf springs lay flat and parallel to the frame if the truck.
dvdswan
Port Orchard, WA
Dave
I totally understand why you did it that way. Having the front body mount right in the area of where the shackle would be for the rear puts a hamper on things too.
Vbb199
Salisbury NC
Vince
I keep starting a topic or thread, name it as one thing, then change my mind and do something else. This was supposed to just be a 1/2 ton sfa swap, using 10 bolts and 36's, now it's became a 1 ton swap using a kingpin 60 and 14b and 39.5 boggers.....
@bucket can you change this title? Lol
Changed it a bit.
So if you have the K5-Ton, is this going to be the S-Ton?
Vbb199
Salisbury NC
Vince
Tonight I finished welding down the rear hangers nice and solid. Somewhat of a PIA because of the shape of the frame... Had to fill in some gaps with 6011 then go back and do a nice hot bead of 7018 to stich it all together.
And in other areas, there's holes in the frame from the factory that I couldn't weld at....
Hindsight is 20/20.
Should've fitted up a plate to the surface first, then I could've had a nice flat place to weld to.
Rachet straps came off of the back since it's fixed to the frame. Took the bumper and grill off so I can get the front hanger in position where I want it, tacked down, and then finally welded.
In the third pic you see, the front half of the frame is angled, so I will need to notch it to make the tube parallel to the ground.... Not a problem.
ExtraZ
