808 k10
hawaii
tom
new seat cover
Last night installed new black lmc cover
808 k10
hawaii
tom
Got seat it back in truck
74 Shortbed
Looks good..
That's not the vent I was talking about, but the one I was talking about is probably used too if they added AC.
Jake_S
Charlotte, NC
350/SM465/NP208
Do you have a pic of the vent you are referring to? Most of the squares I've messed with were AC trucks.
Jake
CRM
Pasco, Washington
Casey
K2500
350 CI
Tore down the original bench seat to see what the damage is going to set me back. The upholstery will be in the $200-250 range. Some of the broken springs I can repair but there are a couple that are broken and the pieces were thrown away by the PO. Hopefully I can find them somewhere. Everything else is in good shape. The bearings need new grease, but that's going to be the easiest part. The foam has some areas that will need to be filled in also.
Jake
I'm on a different computer so I don't have access to my pics so I'll use this one that was just posted.
See the billet band on the passenger side of the dash. Those slotted cutouts are AC vents. Normally on NON AC Trucks, you don't have a vent where there is one in this pic just above the ashtray or the center of the dash.
attachment.php
Jake_S
Charlotte, NC
350/SM465/NP208
HotRod, Thanks for the education. Mine does use that vent.
Jake
Jake
Cool, there you go then. Mount that thing right there. The metal dash behind that pad is open so it'll work fine. I've seen guys on NON AC trucks where that vent isn't used, install their stereo, or Trio Gauge Set.
EDIT, oh wait, you say it DOES use that vent. Thought I seen doesn't. Fuggin glasses are scratched badly. :happy175:
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Installed a new gear reduction starter Friday. What a friggen difference!!! It turns over FAST. For $48 I think it was money well spent too!
Also did the PEX mod on the door strikers - what an improvement, I should have done that years ago! Thanks @HotRodPC for the idea!
took the boys for a ride in the '77. Also took quite a few pics this weekend of the '77
Ramseyryan88
Easley, SC
Ryan
Sierra Grande
Replaced the power steering lines on the GMC in hopes of fixing a leak. Also have an edelbrock carb and intake manifold I scored for $100 to clean up.
Camar068
10 yrs Air Force
Where'd you get the starter from? Nice horsie toys on the bench lol. At first glance I thought it was a dead squirrel or something.
Thanks
OH yeah, Gear reducted starters are the ****. Not to mention smaller and don't hug the block.
GorillaHumper
