donmateo
WI
Haha brakes are always a plus! Sounds like good progress, congrats!
firebane
Calgary, AB
Curtis
Unfortunately that came at a massive cost that I really wasn't wanting to do but its done now so I should be good for quite a long time.
Master Booster = $152
Master Cylinder = $90
Proportioning Valve = $100
Brake Fluid = $30
Soft Lines = $60
2 hard lines = $15
Was not a cheap endeavor by any means. I still need to do 2 new flares plus some actual flare wrenchs.
donmateo
WI
Brake Fluid = $30
Soft Lines = $60
2 hard lines = $15
Aint that always how it goes? I always figure if I'm doing something, best to do it right. Cheaper in the long run.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Some new ranchos 200$ and 36-12.5-16.5 90% tread military tires for 600$
Safe to say I got every mile out a the old ones
Pretty sure you could've just aired them way down and worn down those corners some [emoji1]haha
Replaced the alternator belt after it was discovered to be missing when my truck wouldnt start the other day.
firebane
Calgary, AB
Curtis
Fixed the leak at the master cylinder today with a new fitting and a proper flare on the brake line.
But now I am going to have to get my brake booster fixed *sigh* because when I turn the truck off I can hear air escaping from behind it and the firewall :(
*sigh* Damn remans and will have to warranty it through Rock Auto.
rangerman
Oklahoma
Joe
Heres what ive got done to my sons square the last 6 weeks.
Steering Coupler
Steering Box
New lines from steering box to power steering pump
Radiator
Radiator/heater hoses
Thermostat
Fan clutch
Shocks
New upper and lower complete control arms
Drop spindles
Drop coil springs
Bearings
Rotors
Brake booster
Master cylinder
Dust caps
Calipers
Pads
Rubber brake lines
Metal through frame front brake lines
All tie rod ends
Center drag link
Hellwig sway bar
Pitman arm
Idler arm
Rear flip kit
Drums
Shoes
All hardware in rear brakes
Rear brake line
Wheel cylinders
Wheels/Tires
Radio/speakers
Headliner
Door panels and all trim on panels
Rebuilt entire guts of door
Damn, no wonder im always tired!
donmateo
WI
So when are you coming to do mine? Lol Wow that's quite a list!
r67northern
Louisiana
Leland
Suburban r20
Steering Coupler
Steering Box
Radiator
Thermostat
Fan clutch
Shocks
Drop spindles
Drop coil springs
Bearings
Rotors
Brake booster
Master cylinder
Dust caps
Calipers
Pads
Rubber brake lines
All tie rod ends
Center drag link
Hellwig sway bar
Pitman arm
Idler arm
Rear flip kit
Drums
Shoes
Rear brake line
Wheel cylinders
Wheels/Tires
Radio/speakers
Headliner
Dang, nice work man.
rangerman
Oklahoma
Joe
Bring that wisconsin truck down here, I can try and supervise. :)
Thanks irs been very saturday and sunday, 8-12 hour days.
Every night after work a few hours, im just glad these trucks are easy to work on.
87scotty
Central il
Andrew
V20
5.7 for now
Those 16.5s are hard to air down I'm gonna try running 20-25psi in new ones cause you can see the centers out farther than the sides
Camar068
10 yrs Air Force
What I've done recently:
-front hub bearings (new bearing fell through old race...that bad!)
-ordered Moog ball joints and tie rods (didn't need ball joints, so i've got them for the future....$154 rockauto compare to $290 local (same part #'s))
-LED in dome light (amazon 2ea. for $10)
-left door switch ($9 Napa)
-replaced amp for JBL door speakers (left channel shorted out to chassis...hmm....is that smoke I smell? LOL)
-lights-on reminder buzzer ($4 and 5 minutes)
-Moog rear u-joints ($30)
Near future:
-front Moog u-joints
-Auto-dim w/compass & temp
-driver door hinge detent fix (only top half of spring/detent arm thing was there)
Wish list:
-5.3 fuel injection
-Get rid of those damn .308 gears! (what made GM think to put .308's w/700r4 and 31" tires....on a heavy arse 4x4....beyond me).
Between the frame flex support kit, shocks, tie-rods, the jeep steering shaft and the hub bearings.....damn thing feels like a Cadillac compared to how it was when I bought it.
Don't forget cc20 @ Autozone (online only) for 20% off Military Discount (honor system)
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
I don't think 31" tall were factory? Mine were 235/75r15 which is only a 29" tire
Sent from my Nexus 6 using Tapatalk
Green79Scottsdale
G.R. - MI
Bob
Took the carb apart (again) and adjusted the float level and put the choke back on, correctly this time. Also cleaned up the cluster-f of vacuum lines. Need to double check the timing and pray it starts a couple more times yet. Once to use in family pictures and another to put it to sleep for the winter.
robert8096
Goose Creek SC
Robert
Got the inner fender covers made and the fenders back on.
Working on the poor fitting cowl hood.
My hood hinges came in.
Those inner fender covers look great! How are they fastened in??
LuckyDevil77
