Th400 kickdown switch
Hamgrease
Tennessee
Jonathan
Hey everyone, I have a 85 C10 that was originally a 6.2 diesel/700r4 truck. It now has a 454/400. I’ve installed the kickdown switch solenoid on the petal bracket and made my own harness, it works I’ve tested it. My question is are the accelerator petals different for the TH400 from other transmissions ? My petal doesn’t reach far enough to engage the switch. I’m considering fabricating and welding an adapter rod to it for engagement of the switch.
Rickf
Grafton NH
1974, 1954 & a 1937
Flower power.
Carb'ed Vortec 350
So what you're saying, the switch works fine, just that pedal, when mashed down to the floor, doesn't trigger the switch? Those are designed to kick down at full throttle and under 55. Well, mine won't kick down over 55.
slammed84
Oklahoma
Nick
I believe that factory TH400 cars and trucks did have an specific bracket that had provisions for the kickdown switch. I've looked into this because I also need to install the switch, but it's been awhile since I Googled it. You could try to research it, I'm fairly sure this was the case.
But I'm with you, I would just fab up a bracket that mounts it in the correct position you need, would probably be easier and cheaper than finding the correct pedal/bracket and whatever it takes to mount it correctly in a squarebody.
Hamgrease
Tennessee
Jonathan
Hamgrease
Tennessee
Jonathan
It’s way off
Hamgrease
Tennessee
Jonathan
Hamgrease
Tennessee
Jonathan
Picture was before I reattached the throttle cable
Hamgrease
Tennessee
Jonathan
The bracket for the switch was actually already on the truck I just had to find a bolt to install it I had one
Carb'ed Vortec 350
I fixed it today it works perfectly
Glad you got it fixed and working properly. Having that kickdown with the secondaries roaring sure does get the ticker to tick faster...lol...
JUKA
