Taking off passenger head about 37 bolts so far
Status
Not open for further replies.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Take a big flat screwdriver or medium prybar, put the blade in the teeth of the ring gear straight on, up against the case where convenient and use that to wedge the ring gear from moving. One hand on the screwdriver and the other on the wrench. Do this for all three bolts.
An actual flywheel tool works too, but let's keep it sasquatch style.
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
Preciate it boss
Hugomartin
Banned
Nc
Hugo
When untightening flywhhell from torque converter the engine fan rotated counter clockwise. Thanks
Hugomartin
Banned
Nc
Hugo
Dam I really hope this is a 5/8 wrench on this torque to flywheel bolt
Hugomartin
Banned
Nc
Hugo
Seems an awful lot of play with 5/8 wrench but 9/16 is too small
Rickf
Grafton NH
1974, 1954 & a 1937
Get a metric tool set.
They are short and will usually be either a 5/8 or 11/16". I have very occasionally found them to be metric on some aftermarket torque converters. If 5/8 seems really loose and 9/16" is too tight, try a 15mm.
Radiohead
MCMLXXIX
Yeah, sometimes GM liked to confuse the issue by integrating metric fasteners into the mix. One of the regular posters has actual experience from the manufacturers perspective.
Radiohead
MCMLXXIX
Maybe 16mm too. Yay
Maybe 16mm too. Yay
16mm is almost exactly the same size as 5/8 and is almost never used in any vehicle I've ever worked on. You occasionally come across 14mm and 12mm in some stuff, but the vast majority of fasteners that are metric are going to be 10mm, 13mm, 15mm, or 17mm. Most metric tool kits don't even have a 16mm
Hugomartin
Banned
Nc
Hugo
Seems when I’m trying to undo the bolt the flywheel turns wether I have the breaker bar in or not ?
Hugomartin
Banned
Nc
Hugo
It’s a 15mm so thanks but problem is flywheel still rotates when I try to remove the bolt
Hugomartin
Banned
Nc
Hugo
Thanks I didn’t see this post
Hit it with your purse.
j/k
Seriously though, put the wrench on it with the wrench facing straight down and hit the end of the wrench with a hammer. The shock should break the bolt loose without turning the flywheel. If it is too tight for that to work, put a prybar or big screwdriver on the teeth of the flywheel wedged against the side of the bellhousing on the drivers side.
Status
