!!!!Need Np208 transfer case!!!!
MadOgre
NA
NA
NA
NA
NA
Bought my kit and with overnight shipping it came out to 167$
Ya see I don't know how close you are to anything but its cheaper sometimes to just take a drive and buy it from a shop. I paid $125 (Cndn) including tax for a Quality Gear full rebuild kit.
silverscottsk10
trafalgar indiana
mike
I don't have a vehicle to get anywhere on the weekends
I'll just wait for it a little longer
silverscottsk10
trafalgar indiana
mike
Got my parts 3 days late as it was suppose to be overnighted on Thursday night, can't find my bearing removal tools...can't win once
silverscottsk10
trafalgar indiana
mike
Also, I cannot get this off. I've tried a deadblow, rubber mallet, plastic hammer, and a punch and it will not budge
The four bolts are out, I can't see any others
MadOgre
NA
NA
NA
NA
NA
You need to pry on it. There is a tab built just for that. If you try pushing or beating on the tail housing it will break.
You need to pry where the tail housing meets the main body towards the middle of the main body case. Ill see if I can find a pic for you....
MadOgre
NA
NA
NA
NA
NA
OH scratch that thought! :)
I was thinking 241 uhmm you should be able to tap it with a rubber mallet or try using a small steel putty knife and gently try and work it under with a few taps from a hammer.
Its obviously just glued really well lol so you just need to work at it.
Maybe try putting a boot on it on the ground and then grab the tail housing and give it a good push to the side and pull at the same time. Use a towel to protect the mating surface of the main body.
MadOgre
NA
NA
NA
NA
NA
FYI you should buy the bushing for the tail shaft and see if that shop teacher cant press it out and in for you.
silverscottsk10
trafalgar indiana
mike
Where could I find that?
And I'll try a putty knife, I need the truck by Friday, gf got a new job and our schedules now overlap
MadOgre
NA
NA
NA
NA
NA
I'm not missing anything, just won't break free
I don't know what you did lol but no it should just come off. Its a lot easier to remove when the unit is still in the truck. Its just glued well and now you don't have the leverage with it being disassembled.
MadOgre
NA
NA
NA
NA
NA
Hopefully it was RTV that the last guy used!
ANTvenom
