- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
You can get lucky on lifters. But it's like playing Russian Roulette. As in this case. So far of 16 you've only lost 1 that you know of. So you might think, that's not bad. Only 1 of 16. But when you need all 16 to function properly and not send metal grinds throughout your bearings it's important. And there is also the possibility that the other 15 wiped off just a little found a new comfy home and the grinding stopped but nontheless, you'd still have lost some lobe or lifter base. Sounds like you got the right plan to fix it now with the 88 cam and some new OE style lifters. IIRC, they're only about $2.50 -$3 each. It's been awhile since I bought lifters. I just hope all the shavings didn't go through all your bearings and now your bearings and crank are getting chewed up, or low oil pressure due to chewed up cam bearings.
