Missing sway bar bolts. Anyone know what size they are?
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
So I'm missing the bolts that connect the sway bar ends to the top of the leaf spring. Anyone know what size they are? What bolts would I order?
1976dully
Kansas City MO
C30
They don't mount to the frame with end links?
nvrenuf
Mobile, Al.
No, on a 4wd the ends of the sway bar have eyelets for a large bolt that goes into the leaf spring u-bolt plates.
Stock setup: https://www.lmctruck.com/suspension...eH_KVA7z3McJ3CTTGeylq3mfy4CyM5C0n4rgrWz4TQt8-
If you have at least a 2" lift, I highly recommend the ORD disconnect kit. It really unbinds the front swaybar and makes the ride 100% better.
https://www.offroaddesign.com/swayb...kfrCe04_lJfITiD8lvGwAgGVbVAyOIxJ2t4s4wVN1eZvK
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
89GMCJimmy
ivan
Thanks for the info.
Swaybar is a huge 3/4" bolt with a 1 1/8" head for factory set up.
I would also highly recommend the ORD Kit if you have any lift between 1 1/2-4"​
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Tread specs? Standard I assume? Count?
ButchM
Idaho
Butch
Grumba, you asking for the 77 K5 Blazer?
ButchM
Idaho
Butch
Grumba
Just did some digging (see below, part no 29), all the 4WD use the same bolt. Its 3/4-10 x 3 1/4". The OEM part number is 328130.
Sourcing aftermarket you should ensure the bolt is grade 8 case hardened. That length may be hard to find but a 3 1/2" could easily be shortened.
Good Luck
Butch
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Grumba
Very cool. Thanks man. Much appreciated.
ButchM
Idaho
Butch
No Prob
Hope it helps.
Desertstorm
Michigan
Frank
1986 & 1978
3/4 ton 4wd
I like the idea of the sway bar correction and disconnect system from ORD, I can't quite visualize how this kit will fit on my 86 K20 truck. If both ends of the sway bar are bolted to the leaf pack top plate, what good are the disconnect pins? how does the sway bar connect to the new swing shackle, and then to the crossmember? Pictures would explain everything. If anyone has one of these kits installed on a K20 please post a few pictures
RaisedK5
Leland
Blazer
Thread 'ORD sway bar disconnect' https://www.gmsquarebody.com/threads/ord-sway-bar-disconnect.39294/
Papa Rosa
