LS Square Bodies?
77FullSizeK20
NJ
Nick
Well there were 4 Manual trans available. 2were 3 speeds one four wheel and one two wheel. Then 2 four speeds and again the same one fout wheel and one two wheel. Now as far what trans he most likely has would be the sm 465. I could be wrong but highly dought it.
If you count 2wd and 4wd, then were more than 4 models. SM465 and A883 were both available in 2 and 4wd so there is 4 models, Not sure if either of the 3 speeds were available in 4wd, but if they weren't then there is 6 different manual trans options in Squares. Only 1 of them being an OD option or 2, if you count both 2 and 4wd.
77FullSizeK20
NJ
Nick
And where have you seen square bodies wuth allllll these manual trans. Cause all the ones i see on the road around the tri state and that ive owned only have had the transmissions i mentioned.
Joshua8336
Dirty South AL
Joshua
Classic industries now makes a swap kit for 73-87 gm trucks. the kit includes motor mounts to the frame and engine, & transmission cross member either for t56,4l60e, or 4l80e. classic industries also offers headers in mid length and long tube assortments.
Captain
Va beach
Alex
V20
Newbie
Just started swap. In big black . 1987 suburban v20.
Captain
Va beach
Alex
V20
. 3 days in an I only need fuel tank an sending unit. Won't be here till thrusts
Camar068
10 yrs Air Force
Thanks Joshua, I didn't know that Classic was into the trucks. Have used them in the past for my Camaro. Woohoo......catalog on the way!
Damn, that's a nice rig. And soon to be LS powered? :manos:
Captain
Va beach
Alex
V20
Ls
I did alot of reading about the swap on more sites then I can remember. Thanks to all who have posted anything about there swap I think I read most of them..
My next build is an all aluminum 5.3 ,already at machine shop wooohoooo
Everywayah, Maine
Nick
So a few questions for you LS guys using a th350. How many of you are using the Dakota digital Sen.-01-4160 vss?
What does your factory engine harness look like? I plan on using part of mine to run my fuel pump (ep381 in 87 tank) and my starter. Good idea? Bad idea?
What are you getting for mpgs? I plan on retiring my gmt800 truck for the winter and driving this if it's done in time
Captain
Va beach
Alex
V20
Ls
Well big black is up an running. After 3 weeks waiting for a tank. All is good a lil loud but I can fix that. But great power an sounds good at idle as well
Captain
Va beach
Alex
V20
Just put in the sender from Novak. Same part number. So far so good
Captain
Va beach
Alex
V20
Ls
Making sure it runs good before looming
unimogguy
