Junk r134a adapters?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I recently rebuilt my whole ac with all new parts, but I've been noticing that it doesn't blow cold anymore, i looked around the system for a leak and found that on the accumulator, where I had to put an adaptor for the low pressure side port, it was leaking from the Schrader valve. If i buy one of those cans of refrigerant from the store and try to fill it back up myself without pulling vacuum again would that work? After that id just remove the adaptor from the system
yevgenievich
Place
Name
Year
Model
Size
It would work if there is still some pressure in the system.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
When i take a screw driver and press the Schrader valve i get a little bit of a hiss, not much tho, is that enough?
yevgenievich
Place
Name
Year
Model
Size
Should be ok. Generally trying to avoid the situation where it would normalize with ambient air.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
After you you do it, make sure you have a new adapter waiting. Same thing happened to me about a year ago, and I did the same thing you’re about to do, and it worked out fine.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Yea i just went to take the adapter off, and it sprayed out, i had to put it back on real fast. Im not sure if there's sny pressure left, isnt there a valve behind the adapter?!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, the original R12 valve is behind the adapter. It’s supposed to quit once you pull the adapter all the way off if there’s nothing wrong with it.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Is there a chance the shop pulled off the Schrader valve for the r12 bit? It just blew out when i got the adapter off
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The valve itself is integrated into the accumulator, and you need a valve core removal tool to pull the stem of the valve out. The adapter is intended to go over the R12 low side port as is. Same for the high side adapter. I don’t know why anyone would remove the R12 valve core because if it ever failed again, which they do, you’d unscrew the adapter and loose all your Freon and oil and be back at the evacuation and vacuum phase. The pssh noise when you first unscrew it is normal, but it should go away the more you turn it and be gone whenever the adapter’s off if it was done correctly. So that’s not what happened to you? It just kept going?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
The valve itself is integrated into the accumulator, and you need a valve core removal tool to pull the stem of the valve out. The adapter is intended to go over the R12 low side port as is. Same for the high side adapter. I don’t know why anyone would remove the R12 valve core because if it ever failed again, which they do, you’d unscrew the adapter and loose all your Freon and oil. The pssh noise when you first unscrew it is normal, but it should go away the more you turn it and be gone whenever the adapter’s off. So that’s not what happened to you? It just kept going?
Yea it kept blowing like the valve had been removed by the shop. Im too scared to take it back off and check because i don't wanma loose any pressure i may still have, im gonna go try to get them to hook me up because all the work on that was done by them
Some versions of the adapter have their own valve and you MUST remove the original Schrader valve. They suck because it creates a new potential leak point.
I always use the small aluminum type that take a special socket (although pliers work too). The "valve" in them just pushes on the original valve, so the original valve does all the sealing. They are also small enough that they have a factory-installed appearance.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Could you suggest a link to a better one? Its sounding like I have the first one
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
That’s what I have. The adapters were sitting on the shelf at O’Reilly. My R134a low side adapter had broken exactly as the OP’s did, and whoever “converted” it didn’t install a high side adapter so it worked out well for just a few dollars. It doesn’t make sense to get one that depends on the adapter not failing.
I've always just went to the store and picked stuff out. NAPA has a nice AC parts book with a handful of different adapters. The big thing is to get a type that leaves the original schrader in place.
brentjo
