Ignition module problems
Ypsik10
Ypsilanti mi
Chad
Ok do I do this with the normal plug plugged in as well? And if it fires right up what does this tell me?
350runner
tx
Ceasar
Leave the module plug in. I would get a female spade connector for the positive terminal and leave the factory connector unplugged. If it fires up consistently you'll need a volt meter to check for 12v power at the factory plug.
Sent from my LGLS991 using Tapatalk
Ypsik10
Ypsilanti mi
Chad
Ok cool thanks and if not enough power .. Why don't I have enough power??
350runner
tx
Ceasar
That you'll have to trace with a volt meter and find out.
Ypsik10
Ypsilanti mi
Chad
Seems to be running good now with the ac delco module only had trouble upon start up once...
350runner
tx
Ceasar
Would you mind checking your spark plug gap?
350runner
tx
Ceasar
.035 for stock H.E.I. units.
Ypsik10
Ypsilanti mi
Chad
brand new engine with my stock 100% rebuilt (by me) distributer (using master pro parts) upon start up completely failed again slowly started missing no spark no start for about the tenth time went and bought a new accel stuck it in runs starts perfect!
I'm assuming it was a MasterPro pickup coil, ICM, coil, etc.? That sounds like a recipe for failure to me. Those parts make good spares when you're in a fix, but brands like Duralast and MasterPro have bad reputations as permanent fixes for something in the ignition department. Glad you got it back up and running!
Ypsik10
Ypsilanti mi
Chad
All master pro ! Junk!!!
74 Shortbed
And so is Duralast!!!..
STEELPEGS
