Ignition module problems
Rusty Nail
Rusty
350sbc
This thread is retarded.
Ummm...do you put vaseline under these modules?
Sun tachs...:rolleyes:
350runner
tx
Ceasar
Simple answer. Made in a country with zero respect for quality control. I know everyone has or had one. Spend some time on Google searching for sun pro failure, problems and issues. Check out any American Made product they Will last for ever.
Sent from my LGLS991 using Tapatalk
CSFJ
Dielectric grease
Rusty Nail
Rusty
350sbc
They should sell "dielectric grease" in much bigger quantities. The little tubes SUCK!
Its only fancy Vaseline though, and that **** comes in a TUB! I need a lot!
I know it's stupid but like I said, this thread is retarded.
[yt]cvfxKbpoxRE[/yt]
yevgenievich
Place
Name
Year
Model
Size
It should be thermal compound for heat transfer, dialectic grease can be used in the connectors to help weatherproof and on the battery terminals.
74 Shortbed
Dielectric grease works to a degree but the bad part is it liquefies under heat and becomes useless, thermal grease doesn't..
You'll get a tube of the white heat sink stuff whenever your Delco module comes in.
Ypsik10
Ypsilanti mi
Chad
Yea I always use the tube provided.
Ypsik10
Ypsilanti mi
Chad
Well just got around to putting new ac delco module in same problem still exists .. Barely starts wen cranking bad miss!! Like one cylinder is firing I can get it to start after a few tries and giving it gas..all distributer parts are new top to bottom even recent put another ignition coil in got the wires off valve covers have them ran nicely not touching echother..could it be a timing issue??? Fuel?? It's a brand new holly... Any more ideas??could oil be leaking into the cylinders causing it not to fire up?? Trying to figure it out its my Dailey driver (have a fresh 350 going inn but it's not done yet)
350runner
tx
Ceasar
Have you tried running power straight from the battery?
Ypsik10
Ypsilanti mi
Chad
No I have not but I will what exactly do I do??
350runner
tx
Ceasar
You'll run power from the positive terminal at the battery straight to the distributor at the 12v tap front right next to the tachometer tap. Then turn the key if it fires up you'll need to disconnect this temp run to shut the engine off if it runs.
rmiller62113
