I wanted a small tachometer so. .
JTWard
SE Pennsylvania
James
C1500 Silverado
350 Gasoline
I stated with one those small pods like for 52mm tachometer, But it wouldn't work. So I got one from Summit that had a full adjustment base. Up and down The 80 to 89 or later, but the " A " is on both a angle and a small pitch. So I needed a base that I could cut off an inch off the base without removing the small hold down screw holes. So this one from Summit gave me the adjustment and it was a LED light. I started 3M outdoor double face tape , but it didn't hold so I drilled 2 - 3/32 holes and I used #6 philips screws. I know it looks a little crazy but a change is a change, and I think it looks OK ?
rpcraft
Robert
LS 6.0 364 CID
Nice addition and way to keep it on a smaller scale.
Brian J
Arkansas
K5 Blazer
I like it. Up nice and high so you can see it while driving without having to look down.
rpcraft
Robert
LS 6.0 364 CID
Yeah that is a very nice spot. I know I have been thinking of how to add an analog tach once I finish my LS swap and although I am swapping to a 91 cluster I don't really want to do that gauge that replaces and moves the fuel gauge because I think you lose your 4wd indicator light or something. I'll probably follow your lead, but I might just keep using a BT dongle with a android phone as the interface for the tach and some of the other features that you can display through the Torque App.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
I've been thinking I'd like one mounted on the "A" pillar.
Thanks for showing me it's just what I want!
Craig 85
Nashville, TN
454/TH-400/NP205
Clean set up. I usually throw mine on top of the steering column, so when it's in gear, the gauge is vertical and in between the speedo and fuel gauge. Since my current truck is a low RPM big block, I went to an Autometer #2891 2 5/8" 6000 RPM tach. I still need to get it installed, but here's what the '79 looked like with a similar 3.75".
rpcraft
Robert
LS 6.0 364 CID
Yeah I have never been a fan of that stuff on top of the steering wheel for an automatic. Too much loose and exposed wiring for my taste
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Nice steering wheel
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
We think alike! No messy wiring btw.
Craig 85
Nashville, TN
454/TH-400/NP205
We do. I have the same wheel sitting on the shelf waiting for my K30. I kept the wiring in a loom then tucked it into the rubber gasket on the column so only about 4" of the loom shows. I hate hokey stuff. I even drill into the shifter collar and screw the base in so I don't have a clamp around the column.
rpcraft
Robert
LS 6.0 364 CID
Took a moment to realize I was looking at 2 different trucks!. I am thinking of going with the black 4 spoke style like the lower picture. I think it is all one piece though, very similar to the OEM 4 spoke style that is currently in mine.
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
Nice work!
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
Hell it spun my head a bit...My house is grey with white trim and Ol Glory proudly waving!
JTWard
SE Pennsylvania
James
C1500 Silverado
350 Gasoline
Well see my tachometer is screwed and double faced to the front of the " A " pillar. So it isn't affected by the door slamming or not. It's fixed to the a pillar with the 2 screws and double face tape. But I was only able to set up with LED inside light is lit all the time the engine is running?
78silverado
