Help me identify a vibration
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
That makes more sense. It’d be interesting to hear what your results are when you put it all together.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Whelp. That's right over my head. I'm decent with electricity and circuitry, but I think its a bit much for what I'm dealing with here.
On another note, I suddenly started getting a loud CRACK noise from the driver's front wheel well after sitting for a bit. Haven't dug into it yet, but the couple times its happened I didn't feel it, just heard it. Definitely the driver's front.
I have not done anything to that area in a long time so I'm a little worried something broke.
Tends to happen after I back up then start moving forward again. Last time it did it like 4 times in a row just cruising down my street. I quickly took it home and parked it.
I'm wondering if these things are related?
Carb'ed Vortec 350
It's possible they are related.
350 w/203
Cracked frame behind the steering gear box?
Slipping of the axle under the spring perch?
Carb'ed Vortec 350
The guy on stovebolt reported back....this is copied from his report back of the results....so it may be the pinion bearing going out on yours, definitely worth a check...
"I finished putting the rear end back together in my '62 C10. With the third member rebuild, new U-Joints, and switching from 3.90:1 to 3.38:1 gears, it drives like a completely different truck.
That pinion bearing must have been going out for a long time. The vibrations are gone, the whine is gone and the engine doesn't sound like it's screaming at speed any more."
da_raabi
FloriDUH
Adam
c30
Interesting. Do you happen to have a link for that? I'd like to read more on the process of elimination he went through etc.
yevgenievich
Place
Name
Year
Model
Size
Carb'ed Vortec 350
@yevgenievich thanks. Edit...I didn't check the link you posted, I thought it was the "What have you done to your bolt today" thread.
I sent him a PM asking for additional info. Will let you know if he responds.
Carb'ed Vortec 350
He replied. Of course yours doesn't have the removable third member, the pinion bearings may be the culprit. I removed the link from this response because it was the same one Viktor posted earlier.
rpcraft
Robert
LS 6.0 364 CID
It's surprising but the pinion bearing can take forever to actually get bad to a point where you have a failure. I'd pull the driveshaft off and take a moment to use your hand to see if it has play in it. also if you see any gear oil leaking off the diff that is an indicator as well. A pinion bearing can be replaced pretty easily so long as the mating surface on the pinion has not been scarred. A good shop can probably get it done for a few hours and the parts themselves are less than 100 bucks (probably less than 50 bucks if you bring them to them).
Billy
Dalton Ga
Billy
Mine was a motor mount and my transmission mount.
pinch1020
Massachusetts
Victor
K2500
da_raabi
FloriDUH
Adam
c30
Figured out the issue with the "cracking" sound up front. Turns out something WAS cracking, just not quite what I thought. See anything odd here?
Looks like somebody with little hands decided to play a trick on Daddy while the truck was getting its driveshaft fixed...
Dang kids.
rt66paul
California
paul
1991 suburban
I hate it when that happens.
idahovette
Weiser Idaho
Perry
K20-K10
Just trying to help!!!
kobedemello
