crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
The "vroom-vroom" vibration is typically always driveline, be it u-joints, pinion bearing, dent in the driveshaft, driveshaft weight fell off, trans output bearings, worn splines, worn slip yoke, etc. Next time you take a long-ish drive, say 20 miles or so, feel the diff cover and see if it's warmer than normal. If so, carefully check the snout that houses the pinion bearing. It may be very hot if the bearing is too tight. Bearings can flat-spot but as long as they're getting oil they wont make a sound for a long time. The "45mph only" vibration is typically always tire/wheel related if you feel it in the seat only then it's out back. Front of course could be steering components as well as tires/wheels. If it were me I would try doing a good burnout and see if it gets worse/better/same or different speed. My cousins pulled a prank on my uncle by putting 2 flaps of duct tape on his truck's driveshaft, with 2 opposing flaps about an inch long. It vibrated so bad at 15 mph on their street their dad had to crawl under it and see wtf was going on lol. So at 70mph the imperfection can be so minuscule you may not see it at all.
