Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
84 used up to 7 pins. (85 on location is the convenience center - before that is usually hanging close to the horn relay) if I’m remembering correctly.
I would think it would be pretty easy to modify 77-83 to use it though (minus key).
The easiest way to disable the key warning is to unscrew the door jamb switch, and disconnect and tape off whatever wire isn’t white. If I remember correctly, the wire for the key is tan.
Problem solved.
