headlight/seat belt buzzer
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
84 used up to 7 pins. (85 on location is the convenience center - before that is usually hanging close to the horn relay) if I’m remembering correctly.
I would think it would be pretty easy to modify 77-83 to use it though (minus key).
The easiest way to disable the key warning is to unscrew the door jamb switch, and disconnect and tape off whatever wire isn’t white. If I remember correctly, the wire for the key is tan.
Problem solved.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I think the difference is for seat belt warning. There is a trigger wire for the seat belt switch in the seat belt latch, and another wire that is an output for the seat belt warning lamp in the dash.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I get irritated by the old-school seat belt buzzers because sometimes I just want to sit in the truck with the heat or AC on and not be "reminded" (because I'm not actuallly moving). My newer vehicles don't start hitting the buckle-up nag until you are moving between 5 and 10 MPH which is fine, but I'd probably pull the seatbelt buzzer in a 70's-80's era car. But I do like the headlight buzzer because I often drive to work starting in the gloom with the lights on, but by the time you get there its sunshine and shades time.
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
I've heard you can swap to a module that has a less obnoxious tone.
That's what I installed, it's programable ..
You have a 30 second play time then it loops ...
I used Tubular Bells for the chime ..
Jgonick
West Texas
Joel
I meant it would be extremely easy to modify 77-83 (4 pin) to use the 7 pin alarm module to add the headlight alarm portion. Adding the key alarm portion not as easy because of the key switch in steering column.
The seatbelt portion of the alarm is wired the same from 77 on.
gmbellew
Kansas city
glen
suburban 1500
I think there are OEM chimera modules available from some GM cars of the same vintage that are a direct plug and play.
m
mtbadbob
Montana
Bob
V20
Geez, you could rebuild a transfer case in that same time frame....
YOu can get a soft chime from a 1990s buick or oldsmobile or cadillac and then wire the PINs for the functions you want to have. i would never have a key in ignition chime functioning, but the headlight, sometimes doors are nice to have.
You need to use the connector from the donors tho, these chime modules are larger. And they have more functions so you need a pin out. and they take power too.
Then you can place it anywhere you want to.
SquareRoot
This guy is who I got mine from. Read his threads, it will answer all your questions.
25533906 :)
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I don’t remember the RPO code, but the blue chime module is the holy grail. That’s the one that doesn’t just sound an alarm, it has a Speak N Spell type voice that tells you the key is in the ignition, the door is ajar, the lights are on, trunk open, etc.
Those modules were found in Cadillacs, Buicks, Oldsmobile’s, and higher end cars.
My dad had a 85 Toronado that had that warning system, if I had known then what those modules go for, I would have pulled it out of the car before he sold it!
sherrodmachine
