GMC-IH
dragstews
Belleview Florida US of A
Body 1954, frame 1975
R-100
406 ci SBC
dragstews
R-100
406 ci SBC
The pan holding 6 qts and the filter holding 2 qts nets a 8 qt capacity ...
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
How much oil does a boat engine contain? Wouldn't you match that? Or just match the full mark on the dipstick regardless if it takes 20 gallons of oil?
dragstews
R-100
406 ci SBC
Not sure ??
I bought the pan off of eBay, didn't get a dipstick with it ..
My concern is to not to over fill, want the oil to be below the crankshaft by a inch or two ...
With where I have the oil level almost touching the GM windage tray is going to be my full mark on the dipstick ..
Hadn't got around to making the stick just yet ..
Going to wait till the motor is in the truck cause I want it close to radiator ..
Be easy to reach without climbing on a fender ..
This one is 32 inches long ..
Can get one longer if I see the need ..
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Too much oil above a certain level is not good. I would imagine go with original type dipstick because that would be correct engine level. The extra size oil pan should be designed with that in mind. That's my 2 penny's worth.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
That's my thoughts as well. Just higher capacity, not higher level. The stock dipstick would show the correct level regardless of the pan's capacity
dragstews
R-100
406 ci SBC
Can't use the GM stick ..
They was made with the stick on the side of the pan near the top ..
Mercruiser had there own gig in play with the outlet at the bottom of the pan ..
This design allow for a pump to be attached to the top of the stick to pull the oil out when service denotes ...
With having 6 qts in the slump shouldn't be a need to worry about the motor starving for oil ...
And having the full level about 2 inches below the crankshaft should not cause a problem ...
That 2 inches gives the windage trays room to do their thing ...
I might have overkilled oil control in the lower end, but most likely it's a good place for overkill ?
dragstews
R-100
406 ci SBC
Well ....
The alt bracket doesn't fit the aftermarket 200 amp alt !!
Going to do a bit of "Slice & Dice"
Need a piece of 1/4" flat steel to weld in ...
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
How can you tell they're worn out?
dragstews
R-100
406 ci SBC
The way I removed them is with a punch ..
Hammer on one side to get them tilted in the bore then with vice grips pull them out of the block ..
A few of them was so rusted that the punch broke though the wall ..
Most certainly they was going to leak in a very short time if they wasn't replaced ..
Always do a replacement when rebuilding a motor .. Save a bunch of grief down the road ..
SARG
