GMC-IH
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
dragstews
Jesse
R-100
406 ci SBC
The pan holding 6 qts and the filter holding 2 qts nets a 8 qt capacity ...
Carb'ed Vortec 350
How oil does a boat engine contain? Wouldn't you match that? Or just match the full mark on the dipstick regardless if it takes 20 gallons of oil?
dragstews
Jesse
R-100
406 ci SBC
Not sure ??
I bought the pan off of eBay, didn't get a dipstick with it ..
My concern is to not to over fill, want the oil to be below the crankshaft by a inch or two ...
With where I have the oil level almost touching the GM windage tray is going to be my full mark on the dipstick ..
Hadn't got around to making the stick just yet ..
Going to wait till the motor is in the truck cause I want it close to radiator ..
Be easy to reach without climbing on a fender ..
This one is 32 inches long ..
Can get one longer if I see the need ..
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Too much oil above a certain level is not good. I would imagine go with original type dipstick because that would be correct engine level. The extra size oil pan should be designed with that in mind. That's my 2 penny's worth.
squaredeal91
Greg bush
1991 SB
Another thought I had was with your race gear inside the pan maybe search forums about what the racers are doing for oil levels.
margramby
