Fuel return diy
projectmidnight74
Mississippi
Eddie
V8
Great evening to the gurus of this great forum.
I am in the final stages of finishing up on this project. One of my last 2 missions is to resolve the vapor lock. I plan to purchase the WIC 33040 fuel filter with extra output for return..my thoughts are to route that return to the tank area and create a snug brass fitting on the rubber portion of the vent line.
Good idea or bad idea. I am attaching a pic.
projectmidnight74
Mississippi
Eddie
V8
Pic of tank and fill line and vent line beside it.
nvrenuf
Mobile, Al.
I really think the brass fitting in the hose will leak.
Find a piece of tubing the correct size, put a nipple in the side and splice it in to the vent hose.
I think someone actually makes a tube like I described but I can’t remember who it was.
You could also just change your sending unit to one with 3 ports. My ‘75 already had one, and when I replaced it I found they were stocked at some AutoZone stores. I don’t recall the price.
Robert Bare
MT
Robert
k20
First, are you sure it's vapor lock? Try running it without the gas cap.
I doubt the filter/return will help. How do I know? Because I have a 401 jeep J10, used to haul a camper in it. But, even without the camper, still can do it..did about 2 months ago, hauling wood pellets home. This has the original tank(tiny) up front, then a big one I added years ago, where the spare tire used to hang. Out here, lots of ethanol "winter fuel" most the year. Running ethanol free really helps, but is expensive.
So, years ago, what I did was wrap all the lines in insulation and aluminum foil, from pump to tank.
Yep that helped quite a bit.
What "cured" it?? Added a pusher pump, back along the frame.When it starts to die, staring for fuel, I reach down and turn on the switch and turn pump on. In a few seconds, zoom, off we go!
And this jeep does not even have A/C!
Added the pump probably about 20-25 years ago, for this problem. Most of the small electric pumps have light poppet valves, so even when off the regular fuel pump will draw fuel through them. Easy to check, just suck on one. BUT, have put others on customers trucks, and they just let them run all the time.
OK, that's my 2 cents, and experiences.
projectmidnight74
Mississippi
Eddie
V8
So, I have a file pressure regulator that has the ports but I had to use one to add a gauge to it so I can actually know what my fuel pressure was. I can see the fuel bubbling on the filter after hard drives at **** off. I can also see the blue smoke and it smells like fuel sometimes at idle. It doesn't always do it, but I'm my thought process, when the bowls get full on the Edelbrock it has nowhere to go so it becomes rich and begins to flood. I'm only running 5.5 psi to the carb from a 7psi electric pump so what left needs to go somewhere.
projectmidnight74
Mississippi
Eddie
V8
I just don't want to stop that tank a 3rd time. It sucks lol
Tonimus
Phoenix
Tony
C10 Suburban
If you're only running 5.5psi and the fuel pump is "overpowering" the needle and seat, causing a rich condition, that would also prevent vaporlock. It's more likely that you smell fuel because the burning oil has soiled a spark plug and a cylinder is missfiring. Thus fuel down the exhaust.
If it's just burning oil, it's either valve stem seals, intake seals or sucking in through the PCV. Could also be a cracked head, but far less likely.
projectmidnight74
Mississippi
Eddie
V8
How do you feel about adding a catch can?
ali_c20
Austria
Alexander
C20, K5
I run oil catch cans on my trucks. I was surprised how much oil and whatever they catch. It is definetely a good add on and you can check how much oil is drawn through the pcv. For a system with return I would go the route with a 3 port sending unit, move the pressure gauge to the fuel line with a gauge inline fitting. Use the return port for return. I never do sketchy things on fuel systems and use quality parts cause I don't want to burn down my rides or die in a fireball. My 0,02$
gbashby
