Fix Slamming Doors - Striker Door Latch Repair
79K10
Sacramento,ca
Ryan
350/th350
lmao. always had to slam my squares. doing this once hes back on the road
79K10
Sacramento,ca
Ryan
350/th350
i couldnt wait... I ended up using some duct tape. wrapped it around the striker about 4 or 5 times and now the door closes nicely, no slamming required ...
ill be getting the pex to replace it next time i go to HD..
nice fix. thanks for the info
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
My wife got in mine to make a Lowes run a couple weekends ago. Mind you, the day I replaced the strikers, I called her outside to show how well the doors closed. Well, she gets in and BAM! So, I wait to see if she just forgot, and closed mine softly. We got to Lowes, and she hopped out......BAM!! all over again. Mind you, I have not put the felt in on the pass side yet so the damn windows also banging against the metal. This time I cringe, and I see her looking at me while I'm cringing. NOW she gets the point, right?
She asks to stop by Walmart to get a couple of quick things. I'm staying in the truck, so I drop her at the door, and she doesn't slam it. I go park til she comes back out. When I see her, I roll back up to pick her up and whaddaya know??? BAM!! LOL! That was all I could take. I said, "You may not remember, but I fixed the doors. You no longer have to slam them." She has the nerve to look at me sideways for saying something. Luckily we were only 1.5 mi from the house cause I had to hurry up and get her the hell out before she shattered my ******* glass. I already hate when people slam doors, but when it's a loud tin can of a truck w/not headliner or carpet, it's just that much worse.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I agree with the noise problem in a bare cab my wife slams mine all the time because she says shes not used to them shutting so easily. My doors shut and sound like a brand new truck
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
sounds like a firecracker in a mailbox!
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
Just tried this trick with my impossible-to-close doors. UNBELIEVABLE!!! Thanks for the new doors!!
We hear that alot. Night and Day Difference.
FRANKENTRUCK
By The Sea
Pierce
Now I no longer have to get out of the truck and walk all the way around to close it for my kids!
Mine are acting up, I am back to slamming the drivers side 2 doors again. I don;t know what happened. Maybe put some new pieces in there and make sure the strikers didn't move.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Yesterday while taking a break from splitting wood, Pop grabbed some short pieces of Pex for to use. Grabbed the shortest one, about 3 inches long, his pvc cutter, eye-balled the length, cut two pieces using the drivers side as a guide, and then slit them lenghtwise on the bench. Installed drivers side first, WOW! Passenger side installed, DOUBLE WOW! Even with the windows rolled up the doors shut easily. Before it required some upper body lean with arm pull. Or from the outside a good push with some weight behind it. Now it takes about a quarter of the effort!
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I didnt split mine, I drove it on there with a socket. Not sure how long it will last being split.
Mine are split and work just fine.
FRANKENTRUCK
By The Sea
Pierce
I like the way this sounds! How is it done?
crazy4offroad
K-10
350/SM465/NP205
Just take the striker bolt off, cut a piece of pex to fit the pin, put the pin on a 2x4 or other piece of scrap wood, shoot some wd-40 on it, start the pex on then put a large socket on there that is just big enough to push the pex on. You really have to beat it with a hammer to drive it home but it will go!
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Thanks HotRodPC my doors haven't shut this easily and solidly in years.
Clayton
thatgermanguy
