Engine Backfire Diagnosis Led to Wiped cam Lobes
I wish one of us was there with you, I think we would have had this problem nailed down a while ago. It's much harder to diagnose over the internet.
Skweegle89
Oklahoma
85swb "Fancy"
Your telling me. I have considered putting the damn thing on a trailer and heading down to Caesars house lol. It's got to be valves or the intake or the cam.
350runner
tx
Ceasar
Get err done :) how close are those header bolts broken off on those heads?
Skweegle89
Oklahoma
85swb "Fancy"
They are all sticking out a little ways except one. It's going to be close. Hopefully enough to get a pair of vise grips on. Ongoing to go ahead and put the headers on while I'm messing with it.
350runner
tx
Ceasar
If the vise grip doesn't work try welding on a nut. The heat from that should break the bolt loose.
Skweegle89
Oklahoma
85swb "Fancy"
Well the intake is off. The bottom is clean, but the runners are black. How normal is that?
Skweegle89
Oklahoma
85swb "Fancy"
I meant the ports. The gaskets are still on, so that's why the runners are black lol
Carb'ed Vortec 350
I have never seen the underside of intake shaped like that, but then again I haven't looked inside a lot of engines. Perhaps a single plane intake? As far as the black ports, I don't know, possibly due to the issues you've been having with the backfiring, running rich and such?
Skweegle89
Oklahoma
85swb "Fancy"
I guess I'm going to go ahead and pull everything else off so I can pull the timing cover and make sure I didn't jump a tooth. Leave no stone unturned I reckon.
350runner
tx
Ceasar
Yea that looks like a single plain intake. A lot of folks buy them for street applications, but a single plain trumps it in a daily driven ride.
Skweegle89
Oklahoma
85swb "Fancy"
8 bloody knuckles later, I quit for the night. It's fkn cold out there. This might be a dumb question, but is there some kind of trick to holding the water pump pully so I can get the fan bolts out?
350runner
tx
Ceasar
Belt on I use a vise grip to hold one bolt and a box wrench on another...
Skweegle89
Oklahoma
85swb "Fancy"
**** I already took all the alternator bolts out. I will mess with it tomorrow. If the timing chain is still good, out comes the cam. Then I will put it all back together and do the valve adjustment and see what happens. Hope to have it running this weekend.
350runner
tx
Ceasar
You can do it with out the belt :) if your removing the cam might as well put on a new t chain bud. :)
Skweegle89
Oklahoma
85swb "Fancy"
I plan on putting a double roller on it.
drowe14
