Scottgenex
- Sep 22, 2024
- Utah
- Dakota
- K20
I searched and browsed for a bit, but didn't find anything exactly like my issue.
So. Here's the deal. My 496 swapped '76 K20 has a hydroboost swap from a diesel (just for helpful info) must be getting an air lock, or something like that. I'm not a hydroboost specialist, but understand the workings. A few weeks ago I drove the truck it's furthest distance since the swap and restore. On my return trip (100 miles freeway) the power steering pump was whining when I exited. Brakes had some kickback, steering was lackluster, so I figured it'd aerated while cruising home in rush hour.
Confirmed when there was a lot of fluid spilling out the PS filler neck. The junkyard booster never had much gusto when I put it on, I assumed it was going bad for a while. And now it had fluid coming out of the flange between the master and itself. Ordered a reman and swapped it on. Brakes felt wayyy better. Thought my issue was gone.
Today I cruised the highway for about 30 miles and when I got off it had a repeat issue, this time the brake pedal wouldn't go down more than an inch. I babied it to my buddies trying not to rear end anyone. Checked everything out and saw no leaks. Let it sit for a bit and drove to the gas station, issue mostly gone.
On my return trip I took back roads in case it was RPMs whipping the fluid. Guessing not cause after 20ish minutes of driving it happened. No PS whine. Steering feels just fine. When I press the brakes I have nothing. Just solid pedal. If I steer to a lock it will suddenly sink and skid to a stop like it should. Assuming the turning pushed air out...
I assume the reman hydro is bad cause steering remains fine during the issue.
Can a power steering pump fail internally and cause aeration? All hoses are new. O-Rings are new. The power steering pump is original to the engine. No clue how old it is. I see no leaks. I rechecked tightness of fittings and clamps. All seems to check out. So somewhere air is getting in and locking my unit up?
Again, I'm a newbie with hydo systems. This is all just assumptions I'm making. Looking for suggestions.
Thanks!
Thanks!
