Engine Backfire Diagnosis Led to Wiped cam Lobes
Skweegle89
Oklahoma
85swb "Fancy"
I forget where you live Zach and you don't have it in your location. We're finally getting a few Okies on here and I'm not on enough now to remember everyone's location. Maybe I can swing by and take a look or at least loan an advance wheel timing light.
I'm about 75 miles south of you. Just 10 miles south of Ada.
Skweegle89
Oklahoma
85swb "Fancy"
Hey bud if the t chain is worn it don't mean you have to replace the engine. If it come to it tho I would check the compression and if #s show to be low then get err rebuilt. If it's good go for it and throw a better can in that thing...
I know I don't have to replace it, but with the stupid body lift on it it's impossible to work with, so it's either pull the front clip or pull the motor. I guess I could just pull the clip and replace the chain and cam. Idk. I guess I will cross that bridge when I get there. Just so frustrated with it. The truck didn't cost much, but it drives me nuts to own something I can't use.
350runner
tx
Ceasar
For a cam swap only the rad and condenser has to come out... maybe the core support.maybe. just saying
Hmm, I used to get that way often. At least to Ada. Also to Asher. I always go thru Madil etc going to Durant for Copart, but not in a roll back now, so I dobut I'll be that way near as often.
Skweegle89
Oklahoma
85swb "Fancy"
Then you used to pass right thru here. I'm in the little ol village of Roff Ok.
Skweegle89
Oklahoma
85swb "Fancy"
Carb related.
Carb'ed Vortec 350
Carb related.
I've been waiting hear back about whether the other carb would do any better. Now what, get another q-jet from Mark since he offered to build a different one for you?
350runner
tx
Ceasar
So how's it running now?
Skweegle89
Oklahoma
85swb "Fancy"
Skweegle89
Oklahoma
85swb "Fancy"
I didn't put the holly on it yet, but will in the next day or so. My buddy just pulled his motor yesterday and told me he would bring me the carb as soon as he took it off.
Skweegle89
Oklahoma
85swb "Fancy"
Carb is on its way back. When I put it on the first time, the fuel line fitting wouldn't tighten all the way so I put an o ring in it. When I tightened it down I guess I broke the o ring and a small piece got stuck in the needle/float. Mark got it all fixed up for me and I will have it back Wednesday to try it again.
350runner
tx
Ceasar
Good to hear! Stand up guy huh?
Skweegle89
Oklahoma
85swb "Fancy"
For sure
Nice. Now who is this guy that built it? Where is he? Any contact info?
kobedemello
