- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
yeah your driveline is really sloping downward and appears to be pushing the mount backwards toward the rear of the truck and the crossmember appears to have caught something on the driver side on the slope that caused it to distort slightly. I would gentle massage it with a mallet if it can get close to fitting or cut the excessand possibly drill a hole if need be, but it should get you close enoughwith a little bit of stepfather love to the disobedient stepchild.I guess the W member does bolt to the trans. Not sure if the one for the TH400 would fit.
You must be registered for see images attachYou must be registered for see images attach
Also,
It also appears your mount may be taller than mine or mine is just distorted that much from being broken and worn.
Also is your adapter lose to the sm465? I may be seeing things but it looks like its not fastened
