projo198
- Jan 14, 2025
- Lawson MO
- James
- K10
Wow, great feedback thanks! I like the idea of the 85 cables you showed and could get matching lengths for each side depending on how much I need.Since you are working with a sort of blank slate, here is what the early style is:
And then the later style. Much more simple and how most (likely all) are now.
You’d have to do some measuring to see, but this is the stock passenger side cable for an 85 K30, it’s the long side, almost 53 inches on the housing length. It has that long threaded end for an adjuster, but you could likely cut it short and either use the remaining piece to retain it, or cut it off and put a universal end on it, or adapt the threaded portion to the setup. This is assuming you stick with the earlier style cable system that runs down each frame rail.
Drivers side for an 85 K30, housing is a touch over 33”. Shorter by a good bit than the passenger side, but still longer than the earlier style cables.
For reference a stock 78 K30 cable is a 28 inch long housing.
The end that goes into the axle looks like it is push in rather than the bolt-on bracket mine has, but I believe I could make it work by fabbing that 2-bolt bracket and depending on the size of the hole there.
I was planning on running the cables up the frame rails, welding in eyelet bolts if loop brackets aren't present.
