Early 4.3 upgrade?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
The original issue 4.3 in my 85 swb is tired. Smokes like a 2 stroke tired. IF there is enough wall thickness left, going to rebuild it.
RV cam? Retrofit roller cam? Thermostat temperature? Exhaust w/o egr or smog pump provisions?
Already installed a non-ESC distributor (Jegs with 4 pin icm).
Swapping to a 500cfm capable Holley 2bbl on an adapter, 1/2” spacer, stock iron Qjet high rise intake.
Truck has a Th400 that will also get refreshed. Deep finned aluminum pan, higher flow rate filter, stand alone cooler, new cooler lines.
Rear axle is open 2.73s. Finned aluminum cover, getting new axle seals, internals all look factory new other than the leaking axle seals, pinion seal and tubes. Weld the tube/housing seams fully? Add a truss? Best brand for seals? Used to Mopar 8.75, Ford 9” and Danas, an 8.5” 10 bolt is a bit different.
I’m sure the long term GM guys are rolling their eyes, but, grew up building/driving flatheads and FEs. Not much translates…
Thanks for any parts/building reccomendations and/or tricks.
Seriously with all the people doing LS swaps you should be able to find a usable as is SBC cheaper than you can buy a stock rebuild kit,more power,easiest swap ever and if mpg is your concern use a 305. My 2 cents
If I were to stick with the V6, I'd start with a 4.3 from a '96+ truck. They have much better heads, a balance shaft and a factory roller cam. You can find them used with fairly low miles still. With the money saved from not having to rebuild, there will be money left over for an aluminum intake and an electric fuel pump swap.
Then I'd swap in a transmission with overdrive. A 700r4 would work nicely here and it has a steeper 1st gear too.
Out back, don't worry about welding the tubes or any kind of truss. That's not needed at the power levels of a V6. However, I would swap to a 3.73 or 4.10 gear, depending on tire size. It will make the biggest difference for acceleration than any other modification to the 4.3l. Aside from boost.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
As long as it stays 4.3 and carbed. Not a mpg issue, the truck is mainly cruise nights toy and back up vehicle. I love the WTF factor when I pop the hood… ;)
700r4? I have been turned against them by a 92 K1500 that eats them like a toddler eats cookies. But maybe would survive in a 2wd.
Truck runs P235/75r-15 all terrains out back on stock 6” rally wheels. Dropping the front tire back down to the as built P205/75r15, with st minimum a 3/5 static drop. Again, this is a toy, but if it gets a 700r4 swap, want the correct gear ratio.
Even at a never opened up 40 years old, sparkplugs are a perfect tan, just badly glazed by modern fuel blends. I change them at 24,000 miles, plugs are usually R44 or the Autolite equivalent. Truck got 12-14mpg in town, longer road trips once the carbon thins has seen 22-24mpg. Drive from Memphis to the MS Gulf Coast, 14-18mpg, coming home 22-24mpg. With the 400 and 2.73s. Original owner spec’d it to survive long highway road trips, in Texas.
The "correct" gear ratio isn't determined my keeping the speedometer accurate. The correct gear ratio is determined by the desired mix of power vs. economy. Then the correct speedo drive and driven gears are chosen to make the speedo accurate. The 700r4 can allow for much better acceleration when combined with steeper rear axle gearing, but continue with your current level of economy.
The stock 80's 700r4 used in a 4x4 would often fail at around 125k. They can be made to hold up much better than that. Imho, if your '92 truck is eating them then you are either installing used ones that are failure prone, or they are being poorly rebuilt.
Or the TV geometry is incorrect or the cable adjusted incorrectly.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’ll add that the 700r4 or even a TH350c would likely increase economy by the addition of a lockup torque converter.
Or improper TV cable adjustment (I see Rick beat me too it) or any reused parts are not being cleaned properly or replaced at the time of overhaul. Things like cooler lines, cooler itself.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Make sure its a 87-91 700r4
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
No idea. Engine is 1979 with a midrise tbi intake. Will not accept a stock cable for a 92, have to use the “universal fit” junk. That truck is going Qjet/Th350, currently classified as a “farm special”, not even remotely street legal. But will be…
For the 85 C10, stick with 87+ as a transmission donor? Truck has an 8.5” 10 bolt, so swapping the gears seems easy enough versus Ford/Chrysler removable center section. Yukon Gear still decent? Want to install an Auburn while it is apart, truck can get stuck on wet pavement as is.
Better radiator? Have already replaced it once, the plastic tanks don’t seem to seal well. Silicone hoses worth the cost? Heater does not get hot, so figuring that when L’homme Ancien (late father in law) added Dexcool that became mud in a week, it screwed up the entire cooling system.
I don’t mind spending the money on decent parts. Built a 41 Pontiac flathead 6 in 1993 that was still going strong in 2011 when I moved. Car belongs to an old friend in WA. Would like to shoot for at least that out of this rig.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Lots of info on 4.3s here
Very valuable stuff in post #2
Dang… Gonna have to steam clean my engine/bay and see what it turns out to be. Engine was always smooth as glass, until the distributor, ESC, and carb decided they did not want to play anymore. Then it broke both motor mounts, started dumping fuel, and pouring oil out of the rear main seal. About the same time, it started leaking atf and gear oil, like somebody flipped a switch, engine, transmission and rear axle all developed issues.
I’d like to get it as clean as the first pic, versus the crust monster in the others. Can’t even see the engine for all the emissions related trash.
Just pointing it out in case it wasn't obvious... that's and old article and the 4.3 lived on for a good number of years after '98. I think until '12 or so? Relatively unchanged from what was offered in '98.
good to note the since then 4.3 isnt the same as the sbc derived 4.3 , since that could seem like it would be at first glance
zacharyb
