Early 4.3 upgrade?
good to note the since then 4.3 isnt the same as the sbc derived 4.3 , since that could seem like it would be at first glance
Right. Iirc, the newer generation 4.3 was derived from the LT series (gen 4?) of small block.
At least it doesnt have AFM! But they are kinda severely underpowered compared to the 4.8/5.3/6.0/6.2 +
nevermind, apparently it DOES have AFM. and its a 5th gen LS
Old Guy Bill
KY
Bill
Wow! Great info here I never knew about the 4.3.
I remember way back when it first came out in the S10 trucks. It was supposedly a V8 with two less cylinders design.
That engine was a tire burner in those little trucks.
thats why a vortec late 90s one is worth it, its got more hp, a balance shaft (a huge win for smoothness), and its still a SBC under the hood really
Pretty sure the accessory drive would still be the same but not sure how long that remains true going into the 2000s
My '04 Blazer still has the same accessory drive that was used starting in '96. Iirc, my buddy's old '07 C1500 did as well. It's an incredibly easy system to adapt into a squarebody.
vr1967
Virgil
k1500
6.2L turbo
While not really relevant to the original post, Some of the later engine changes (post 98) included elimination of the egr valve and updated injector design in 02-03 and updated ignition in 07, that used a 58x reluctor wheel instead of the 3x that had been used since ‘96.
Also, around 99-2000, the crank pilot bores changed to allow the 300mm shaft transmission to be used.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Original plan was 350-455 (Buick), 425/472/500 Cadillac, a matching Th400, and slip an Auburn or mini spol in with the 2.73s. Bad back, knees, hips and shoulders.
350 buick is cool idea >:)
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
It’s a hard to find idea in sw Tennessee. As soon as a complete with transmission one pops up, it sells. Ditto 455s, can get Oldsmobile or Pontiac fairly easily, Buick? Nope.
RWD Cadillac here I’d have to buy a complete car.
Go 455 olds,good engines tons of torque and it's a bolt in using 5.7 diesel mounts.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Has to have a front mount dizzy to justify the swap.
Had a 72 Cutlass sourced 455 in a 30’ wooden hulled cabin cruiser. Even seen that heavy (12,00#) up on plane? She’d do it at 1/3 throttle. Got Katrinad in Bay St Louis MS.
yessss
cmichels83
Fargo
Craig
I have had good experiences with the 4.3 in the early 90s. Had a 1990 silverado and later a 92 GMC Sierra, both 2wd with the manual 5 speed. They got 20+ mpg in town and on the highway. Ran them somewhere between 250,000 and 300,000. Tough to know for sure because the speedometers worked only half the time. Miss those trucks as daily driving. Drove the 90 to the wrecking yard after the engine started only hitting on 5 cylinders. Got $500 for it and then bought the 92 GMC. Drove that till I needed an extended cab for hauling the kids.
i think the old 4.3 died when the new one came out coincided with retirement of the 4l60e
2013 was last year for the 4l60e
2014+ is the new 4.3
updoot
which means the new generation silverado, to replace the gmt900, got them
tball67
