Dingleball Hones
Carb'ed Vortec 350
I am getting ready to order some dingleball hones to clean up some cylinder bores on different engines. I see they come in various grits. What would be the recommended grit to get? 240, 320, or 400? Cast iron rings will be on the pistons. I was thinking 320, but wanted to ask here. This goes for the lifter bores as well.
Carb'ed Vortec 350
Just skimming through that he said 280 rings will seat faster. I have a LS that was locked up I was going to try on
220 for cast iron or chrome rings, but finer grits for other rings.
Fat 454
Australia
C20 Suburban
I'm sure your all over that you need the expandable straight hones to clean up a bore, and the dingle balls just put a cross hatch finish on to hold an oil film.
If you use the balls to "re-furb" a bore, they will not hold a true straight wall, and just follow any bulges or ridges already there ..
hey mister
North Coast
Marty
When I rebuilt my GoldWing engine, I contacted Total Seal to get the info on cylinder finish. They guided me on grit and technique to get the correct crosshatch pattern.
Grit is only half the equation. Crosshatch pattern angle is just as critical for break in.
I would contact the ring mfg and chat with them.
You only get one chance for break in.
Carb'ed Vortec 350
One has true bores, the other is getting a hillbilly rebuild. Engine runs fine, just going to do some redoing when I open it up. It developed a knock upon start-up, no shavings in the oil. New bearings, rings and seals, everything else has been gone through. The one with true bores is all fresh, just needs a little clean up before assembly.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I don't really like them, but as a former engine builder, go with the 400. It would be much better to take to a machine shop.....just saying. Yes it will cost more. I do have one in my tool box though, never used.
Raisen
