AaronW
- Mar 24, 2021
- MT
- Aaron
- V3500
All:
So after days of soaking, heat, soaking, heat...., I broke both upper mounting studs for my rear shocks. I picked up some grade 8 bolts that should work but am contemplating the best way to fix them. I could cuts the mounting brackets off, drill a hold through where the original mounting stud is, run the bolt through, and then weld the brackets back on.
But the more I look at it, the more it looks to me as though the original mounting stud is just welded to the front of the bracket. At least, I can't see where it comes through on the inside.
So what's the best way to go here?
Aaron
Aaron
